Live UAV operations
1. Publish UAV
  • x-api-key: <your_api_key>
Note:
        "latitude": 50.7,
        "longitude": 4.2
        "id": "UAV3",
        "latitude": 50.8,
        "longitude": 4.1
        "id": "UAV4",
2. Get Aircraft
Endpoint: GET /v1/uav
Description
Use case
Request Headers
Notes
  • Search mode selection:
Query Parameters
lat double No Latitude in decimal degrees (4 decimal precision). Required for radius search. 0
lng double No Longitude in decimal degrees (4 decimal precision). Required for radius search. 0
viewport string No Bounding box to retrieve traffic, formatted as lat_min,lng_min,lat_max,lng_max (4 decimal precision is sufficient). —
alt_min int No Filter aircraft below the given altitude in AMSL meters. 0 means unused. 0
alt_max int No Filter aircraft above the given altitude in AMSL meters. 0 means unused. 0
rad int No Radius in meters from the reference point (maximum 20,000 m). Used only when viewport is not provided. 10000
show_grounded boolean No Include traffic with GROUNDED status if set to true. false
Response
Example Response
