Live UAV operations
1. Publish UAV
  • x-api-key: <your_api_key>
Note:
        "latitude": 50.7,
        "longitude": 4.2
        "id": "UAV3",
        "latitude": 50.8,
        "longitude": 4.1
        "id": "UAV4",
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
Description:
Retrieve a list of airborne aircraft traffic either within a specificcircular radius andaround altitudea rangereference frompoint, theor givenwithin latitudea andviewport longitude.rectangle (bounding box).
By default, the radius-based search radius isuses 1000010,000 meters, with a maximum of 2000020,000 meters. Altitude filters apply in both modes.
Use case:
NoteNotes:
    If you have published UAvsUAVs tovia thethis API, they willmay beappear part ofin the response.response
    depending on the filters.
    Search mode selection:
      Use viewport to retrieve traffic inside a map bounding box (recommended for map-based UIs). Otherwise, use lat + lng with rad for a circular proximity search.
      lat double YesNo Latitude in decimal degrees (4 decimal precision). Required for radius search. N/A0
      lng double YesNo Longitude in decimal degrees (4 decimal precision). Required for radius search. N/A0
      viewport string No Bounding box to retrieve traffic, formatted as lat_min,lng_min,lat_max,lng_max (4 decimal precision is sufficient). — alt_min int No Filter all aircraft below the given altitude in AMSL meters. Zero0 means 'unused'.unused. 0 alt_max int No Filter all aircraft above the given altitude in AMSL meters. Zero0 means 'unused'.unused. 0 rad int No Radius in meters from the reference point (maximum:maximum 2000020,000 meters)m). Used only when viewport is not provided. 10000 show_grounded stringboolean No ReturnInclude traffic with GROUNDED status.status if set to true. false
      Example Request1: Radius-based request:
      GET /v1/uav?latitude=lat=48.8588&longitude=lng=2.2943&altitude_min=alt_min=1000&altitude_max=alt_max=3000&radius=rad=15000
      Example Response
          "latitude":
      Similar48.86584, response"longitude": as2.63723, Get"beacon_type": Nearby"JET", Aircraft"call_sign": will"IBE06CK", be"transponder_type": returned.
      "ADS-B", "last_update": 1733412793, "altitude": 10554, "course": 205, "ground_speed": 237, "status": "AIRBORNE", "id": "3423C3" } ]
