Live UAV operations
1. Publish UAV
Note:
ground_speed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
"latitude": 50.7,
"longitude": 4.2
"id": "UAV3",
"latitude": 50.8,
"longitude": 4.1
"id": "UAV4",
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
lat |
lng |
alt_min |
alt_max |
rad |
