Live UAV operations
  • x-api-key: <your_api_key>
Note:
Example POST Request to submit 1 UAV position:
Example POST Request to submit multiple UAV position:
        "latitude": 50.7,
        "longitude": 4.2
        "id": "UAV3",
        "latitude": 50.8,
        "longitude": 4.1
        "id": "UAV4",
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
