Live UAV operations
x-api-key: <your_api_key>
Note:
icao24 field with the transponder's hexadecimal code. For more details, see the SafeSky FAQ.
id
string
Yes
Unique identifier for the UAV.
last_update
long
Yes
The time of the event in seconds since epoch at UTC-0.
latitude
double
Yes
Latitude in decimal degrees (4 decimal precision).
longitude
double
Yes
Longitude in decimal degrees (4 decimal precision).
altitude
int
Yes
Altitude of the UAV in AMSL meters. Use -9999 if altitude is unknown
ground_speed
int
Yes
Ground speed of the UAV in meters per second.
course
int
Yes
Direction of travel in degrees clockwise relative to true north.
status
string
Yes
Current status of the UAV (INACTIVE, AIRBORNE, GROUNDED).
alt_min
int
No
Filter all aircraft below the given altitude in AMSL meters. Zero means 'unused'.
0
alt_max
int
No
Filter all aircraft above the given altitude in AMSL meters. Zero means 'unused'.
0
return_nearby_traffic
boolean
No
Return information about aircraft traffic within proximity of the UAV positions.
false
rad
int
No
Radius distance in meters from all UAV reference point (maximum: 20000 meters).
10000
return_grounded_traffic
boolean
No
Include grounded beacons.
false
Example POST Request:
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
lat
double
Yes
N/A
lng
double
Yes
N/A
alt_min
int
No
0
alt_max
int
No
0
rad
int
No
Radius in meters from the reference point (maximum: 20000 meters).
10000
