Live UAV operations
Description:Publishes one or many UAV position to the SafeSky platform. Optionally, it's returning a list of nearby aircraft for each UAV position within a default radius of 10000 meters. This response will not include the UAV you have posted. Request Headers:
  • x-api-key: <your_api_key>
Note:
altitude int Yes Altitude of the UAV in AMSL meters.
Example POST Request:
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
