Live UAV operations
Note:
ground_speed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
lat |
lng |
alt_min |
alt_max |
rad |
