Live UAV operations
Note:
icao24 field with the transponder's hexadecimal code.For more details, see the SafeSky FAQ.
ground_speed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
SimilarExample response as Get Nearby AircraftResponse will be returned.:
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
lat |
lng |
alt_min |
alt_max |
rad |
Similar response as ExampleGet ResponseNearby Aircraft: will be returned.
[td:nth-child(1) {
width: 20%;
th:nth-child(2), td:nth-child(2) {
width: 15%;
th:nth-child(3), td:nth-child(3) {
width: 10%;
th:nth-child(4), td:nth-child(4) {
width: 55%;
