Live UAV operations
Description:Publishes one or many UAV position to the SafeSky platform. Optionally, it's returning a list of nearby aircraft for each UAV position within a default radius of 10000 meters. This response will not include the UAV you have posted. Request Headers:
  • x-api-key: <your_api_key>
Note:
  • If your UAV is equipped with an ADS-B, FLARM, or ADS-L transponder, you must populate the icao24 field with the transponder's hexadecimal code.
    For more details, see the SafeSky FAQ.
altitude int Yes Altitude of the UAV in AMSL meters.
Example POST Request:
2. Get Nearby Aircraft
Endpoint: GET /v1//uav
