Live UAV operations
You can poll withusing GET and push data using POST as frequently as every 5 seconds, providing a balanced trade-off between latency and situational awareness. If necessary, the minimum polling and push withinterval POSTcan asbe often as 5 seconds, which is a good balance between latency and situation awareness. If really needed, the minimum poll and push is one second.
1. Get Nearby Aircraft
Endpoint: GET /v1//uav
x-api-key<your_api_key>Note: If you have published UAvsreduced to the1 API,second theyfor willreal-time be part of the response.responsiveness.
latdoublelngdoublealt_minintalt_maxintradintResponse:
2.1. Publish UAV and Get Nearby Aircraft
Note: UAVs that you have published in this POST are excluded from the response.
ground_speed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
2. Get Nearby Aircraft
x-api-key: <your_api_key>
lat
double
Yes
N/A
lng
double
Yes
N/A
alt_min
int
No
0
alt_max
int
No
0
rad
int
No
Radius in meters from the reference point (maximum: 20000 meters).
10000
