Live UAV operations
1. Get Nearby Aircraft
Endpoint: GET /v1//uav
x-api-key:<your_api_key>
lat |
lng |
alt_min |
alt_max |
rad |
Note: UAVs that you have published in this POST are excluded from the response.
ground_speed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
