Live UAV operations
1. Get Nearby Aircraft
Endpoint: GET /v1//uav
x-api-key:<your_api_key>
Note: If you have published UAvs to the API, they will be part of the response. By default, your own UAVs are excluded from the response.
lat |
lng |
alt_min |
alt_max |
rad |
groundSpeed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
