Live UAV operations
1. Get Nearby Aircraft
Endpoint: GET /uav
lat |
lng |
alt_min |
alt_max |
rad |
Endpoint: POST /uav
groundSpeed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
