Live UAV operations
1. Get Nearby Aircraft
Endpoint: GET /uav
ParameterTypeRequiredDescriptionDefault
latdoubleYesLatitude in decimal degrees (4 decimal precision).N/A
lngdoubleYesLongitude in decimal degrees (4 decimal precision).N/A
alt_minintNoFilter all aircraft below the given altitude in AMSL meters. Zero means 'unused'.0
alt_maxintNoFilter all aircraft above the given altitude in AMSL meters. Zero means 'unused'.0
radintNoRadius in meters from the reference point (maximum: 20000 meters).10000
Endpoint: POST /uav
FieldTypeRequiredDescription
idstringYesUnique identifier for the UAV.
last_updatelongYesThe time of the event in seconds since epoch at UTC-0.
latitudedoubleYesLatitude in decimal degrees (4 decimal precision).
longitudedoubleYesLongitude in decimal degrees (4 decimal precision).
altitudeintYesAltitude of the UAV in AMSL meters.
groundSpeedintYesGround speed of the UAV in meters per second.
courseintYesDirection of travel in degrees clockwise relative to true north.
statusstringYesCurrent status of the UAV (INACTIVE, AIRBORNE, GROUNDED).
return_nearby_trafficbooleanNoReturn information about aircraft traffic within proximity of the UAV positions.false
radintNoRadius distance in meters from all UAV reference point (maximum: 20000 meters).10000
return_grounded_trafficbooleanNoInclude grounded beacons.false
Example POST Request:
Similar response as Get Nearby Aircraft will be returned.
3. Check for API health
Endpoint: GET /
Description:
For assistance or further inquiries, please contact us at support@safesky.app or visit our website.
