HMAC Auth SDK for Python
SafeSky HMAC Authentication SDK for Python
Python SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
API Endpoint: All requests use https://uav-api.safesky.app. Each API key is associated with either a sandbox or production environment. The gateway automatically routes your request to the correct backend based on the environment configured for your API key.
Installation
No external dependencies required! This SDK uses only Python standard library.
## Simply copy safesky_hmac_auth.py to your project
Requirements:
  • Python 3.6+
Quick Start
import safesky_hmac_auth as auth
## Your SafeSky API key
API_KEY = 'YOUR_SAFESKY_API_KEY_HERE'
## Generate authentication headers
headers = auth.generate_auth_headers(
    API_KEY,
    'GET',
    'https://sandbox-public-uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'
    ## 'https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'  ## Production
## Use with your HTTP client
## headers contains: Authorization, X-SS-Date, X-SS-Nonce, X-SS-Alg
Usage Examples
Example 1: GET Request (Nearby Aircraft)
import http.client
import json
from urllib.parse import urlparse
## Generate headers
url = 'https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000'
headers = auth.generate_auth_headers(API_KEY, 'GET', url)
## Make request
parsed_url = urlparse(url)
conn = http.client.HTTPSConnection(parsed_url.hostname)
conn.request('GET', parsed_url.path + '?' + parsed_url.query, headers=headers)
response = conn.getresponse()
data = response.read().decode('utf-8')
print(json.dumps(json.loads(data), indent=2))
conn.close()
import json
import time
## Prepare body
body_data = [{
    "id": "my_uav_001",
    "altitude": 110,
    "last_update": int(time.time()),
    "call_sign": "Test UAV",
    "ground_speed": 10,
    "vertical_rate": 5
body = json.dumps(body_data)
## Generate headers (pass body for POST)
url = 'https://uav-api.safesky.app/v1/uav'
headers = auth.generate_auth_headers(API_KEY, 'POST', url, body)
headers['Content-Type'] = 'application/json'
## Make request with body
conn = http.client.HTTPSConnection('api.safesky.app')
conn.request('POST', '/v1/uav', body=body, headers=headers)
print(f'Status: {response.status}')
conn.close()
Complete Examples
The SDK includes 5 complete examples in example.py:
## URL includes query parameters
url = 'https://uav-api.safesky.app/v1/uav?return_nearby_traffic=true'
body = json.dumps([...])  ## Your UAV data
## Query params are automatically included in signature
body_data = {
    "features": [{
            "id": "advisory_001",
            "max_altitude": 111,
            "call_sign": "Test Advisory",
            "remarks": "Testing"
            "coordinates": [[
                [4.38, 50.69],
                [4.40, 50.69],
                [4.40, 50.70],
                [4.38, 50.70],
                [4.38, 50.69]
url = 'https://uav-api.safesky.app/v1/advisory'
Example 5: Using with requests library
import requests
## GET request
url = 'https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'
response = requests.get(url, headers=headers)
print(response.json())
## POST request
response = requests.post(url, data=body, headers=headers)
print(response.status_code)
Example 6: Using with urllib
import urllib.request
req = urllib.request.Request(url, headers=headers)
with urllib.request.urlopen(req) as response:
    print(data)
API Reference
generate_auth_headers(api_key, method, url, body='') → Dict[str, str]
Parameters:
  • api_key (str): Your SafeSky API key (e.g., ssk_live_...)
  • method (str): HTTP method (GET, POST, etc.)
  • url (str): Full URL including protocol, host, path, and query string
  • body (str, optional): Request body for POST/PUT requests (default: empty string)
Returns: Dictionary with authentication headers:
    'Authorization': 'SS-HMAC Credential=...',
    'X-SS-Date': '2025-11-12T14:30:00.123Z',
    'X-SS-Nonce': 'uuid-v4',
    'X-SS-Alg': 'SS-HMAC-SHA256-V1'
Lower-Level Functions
For advanced use cases, you can use individual functions:
  • derive_kid(api_key) → str - Derives Key Identifier from API key
  • derive_hmac_key(api_key) → bytes - Derives HMAC signing key using HKDF
  • build_canonical_request(...) → str - Builds canonical request string
  • generate_signature(canonical_request, hmac_key) → str - Generates HMAC-SHA256 signature
  • generate_nonce() → str - Generates UUID v4 nonce
  • generate_timestamp() → str - Generates ISO8601 timestamp with milliseconds
Authentication Flow
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Security Notes
  • Use environment variables: Store keys in .env files
Troubleshooting
Invalid Signature
Check:
Replay Attack Detected
Timestamp Out of Range
Authentication Failed
Running Examples
## or update URL to https://uav-api.safesky.app for production
python example.py
For questions or issues:
  • Email: support@safesky.app
