HMAC Auth SDK for Python
Python SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
Installation
No external dependencies required! This SDK uses only Python standard library.
### Simply copy safesky_hmac_auth.py to your project
Requirements:
  • Python 3.6+
Quick Start
import safesky_hmac_auth as auth
### Your SafeSky API key
API_KEY = 'YOUR_SAFESKY_API_KEY_HERE'
### Generate authentication headers
headers = auth.generate_auth_headers(
    API_KEY,
    'GET',
    'https://sandbox-public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'
    ### 'https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'  ### Production
### Use with your HTTP client
### headers contains: Authorization, X-SS-Date, X-SS-Nonce, X-SS-Alg
Usage Examples
Example 1: GET Request (Nearby Aircraft)
import http.client
import json
from urllib.parse import urlparse
### Generate headers
url = 'https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000'
headers = auth.generate_auth_headers(API_KEY, 'GET', url)
### Make request
parsed_url = urlparse(url)
conn = http.client.HTTPSConnection(parsed_url.hostname)
conn.request('GET', parsed_url.path + '?' + parsed_url.query, headers=headers)
response = conn.getresponse()
data = response.read().decode('utf-8')
print(json.dumps(json.loads(data), indent=2))
conn.close()
import json
import time
### Prepare body
body_data = [{
    "id": "my_uav_001",
    "altitude": 110,
    "last_update": int(time.time()),
    "call_sign": "Test UAV",
    "ground_speed": 10,
    "vertical_rate": 5
body = json.dumps(body_data)
### Generate headers (pass body for POST)
url = 'https://api.safesky.app/v1/uav'
headers = auth.generate_auth_headers(API_KEY, 'POST', url, body)
headers['Content-Type'] = 'application/json'
### Make request with body
conn = http.client.HTTPSConnection('api.safesky.app')
conn.request('POST', '/v1/uav', body=body, headers=headers)
print(f'Status: {response.status}')
conn.close()
Complete Examples
The SDK includes 5 complete examples in example.py:
### URL includes query parameters
url = 'https://api.safesky.app/v1/uav?return_nearby_traffic=true'
body = json.dumps([...])  ### Your UAV data
### Query params are automatically included in signature
body_data = {
    "features": [{
            "id": "advisory_001",
            "max_altitude": 111,
            "call_sign": "Test Advisory",
            "remarks": "Testing"
            "coordinates": [[
                [4.38, 50.69],
                [4.40, 50.69],
                [4.40, 50.70],
                [4.38, 50.70],
                [4.38, 50.69]
url = 'https://api.safesky.app/v1/advisory'
Example 5: Using with requests library
import requests
### GET request
url = 'https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'
response = requests.get(url, headers=headers)
print(response.json())
### POST request
response = requests.post(url, data=body, headers=headers)
print(response.status_code)
Example 6: Using with urllib
import urllib.request
req = urllib.request.Request(url, headers=headers)
with urllib.request.urlopen(req) as response:
    print(data)
API Reference
generate_auth_headers(api_key, method, url, body='') → Dict[str, str]
Parameters:
  • api_key (str): Your SafeSky API key (e.g., ssk_live_...)
  • method (str): HTTP method (GET, POST, etc.)
  • url (str): Full URL including protocol, host, path, and query string
  • body (str, optional): Request body for POST/PUT requests (default: empty string)
Returns: Dictionary with authentication headers:
    'Authorization': 'SS-HMAC Credential=...',
    'X-SS-Date': '2025-11-12T14:30:00.123Z',
    'X-SS-Nonce': 'uuid-v4',
    'X-SS-Alg': 'SS-HMAC-SHA256-V1'
Lower-Level Functions
For advanced use cases, you can use individual functions:
  • derive_kid(api_key) → str - Derives Key Identifier from API key
  • derive_hmac_key(api_key) → bytes - Derives HMAC signing key using HKDF
  • build_canonical_request(...) → str - Builds canonical request string
  • generate_signature(canonical_request, hmac_key) → str - Generates HMAC-SHA256 signature
  • generate_nonce() → str - Generates UUID v4 nonce
  • generate_timestamp() → str - Generates ISO8601 timestamp with milliseconds
Authentication Flow
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Security Notes
  • Use environment variables: Store keys in .env files
Troubleshooting
Invalid Signature
Check:
Replay Attack Detected
Timestamp Out of Range
Authentication Failed
Running Examples
### Make sure server is running on localhost:8080 for local testing
### or update URL to https://api.safesky.app for production
python example.py
For questions or issues:
  • Email: support@safesky.app
