HMAC Auth SDK for Java
SafeSky HMAC Authentication SDK for Java
Java SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
API Endpoint: All requests use https://uav-api.safesky.app. Each API key is associated with either a sandbox or production environment. The gateway automatically routes your request to the correct backend based on the environment configured for your API key.
Installation
No external dependencies required for the core library! Uses only Java standard library.
Requirements:
  • Java 17+ (for text blocks and modern APIs)
<!-- For the example file only (optional), add Gson for JSON handling -->
<dependency>
    <groupId>com.google.code.gson</groupId>
    <artifactId>gson</artifactId>
    <version>2.10.1</version>
</dependency>
Quick Start
import java.util.Map;
public class QuickStart {
    public static void main(String[] args) {
        // Your SafeSky API key
        String apiKey = "YOUR_SAFESKY_API_KEY_HERE";
        Map<String, String> headers = SafeSkyHmacAuth.generateAuthHeaders(
            apiKey,
            "GET",
            "https://sandbox-public-uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908",
            // "https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908",  // Production
            null  // body is null for GET requests
        // Use with your HTTP client
        // headers contains: Authorization, X-SS-Date, X-SS-Nonce, X-SS-Alg
Usage Examples
Example 1: GET Request (Nearby Aircraft) with HttpURLConnection
import java.net.HttpURLConnection;
import java.net.URI;
String url = "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000";
// Generate headers
Map<String, String> headers = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "GET", url, null);
// Make request
HttpURLConnection conn = (HttpURLConnection) URI.create(url).toURL().openConnection();
conn.setRequestMethod("GET");
// Add auth headers
for (Map.Entry<String, String> header : headers.entrySet()) {
    conn.setRequestProperty(header.getKey(), header.getValue());
int statusCode = conn.getResponseCode();
// Read response...
conn.disconnect();
import com.google.gson.JsonArray;
import com.google.gson.JsonObject;
import com.google.gson.Gson;
import java.io.OutputStream;
import java.nio.charset.StandardCharsets;
String url = "https://uav-api.safesky.app/v1/uav";
// Build JSON body
JsonArray bodyArray = new JsonArray();
JsonObject uav = new JsonObject();
uav.addProperty("id", "my_uav_001");
uav.addProperty("altitude", 110);
uav.addProperty("latitude", 50.69378);
uav.addProperty("longitude", 4.39201);
uav.addProperty("last_update", System.currentTimeMillis() / 1000);
uav.addProperty("status", "AIRBORNE");
uav.addProperty("call_sign", "Test UAV");
uav.addProperty("ground_speed", 10);
uav.addProperty("course", 250);
uav.addProperty("vertical_rate", 5);
bodyArray.add(uav);
String body = new Gson().toJson(bodyArray);
Map<String, String> headers = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "POST", url, body);
// Make request
conn.setRequestMethod("POST");
conn.setDoOutput(true);
conn.setRequestProperty("Content-Type", "application/json");
// Write body
try (OutputStream os = conn.getOutputStream()) {
    byte[] input = body.getBytes(StandardCharsets.UTF_8);
    os.write(input, 0, input.length);
conn.disconnect();
Complete Examples
The SDK includes 5 complete examples in SafeSkyHmacExample.java:
// URL includes query parameters
String url = "https://uav-api.safesky.app/v1/uav?return_nearby_traffic=true";
String body = /* JSON body */;
// Query params are automatically included in signature
String url = "https://uav-api.safesky.app/v1/advisory";
long timestamp = System.currentTimeMillis() / 1000;
String body = """
        "id": "advisory_001",
        "max_altitude": 111,
        "last_update": %d,
        "call_sign": "Test Advisory",
        "remarks": "Testing"
        "coordinates": [[
          [4.38, 50.69],
          [4.40, 50.69],
          [4.40, 50.70],
          [4.38, 50.70],
          [4.38, 50.69]
""".formatted(timestamp);
Example 5: Using with Apache HttpClient
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.HttpClients;
String url = "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908";
try (CloseableHttpClient httpClient = HttpClients.createDefault()) {
    HttpGet request = new HttpGet(url);
    // Add auth headers
        request.addHeader(header.getKey(), header.getValue());
    httpClient.execute(request);
Example 6: Using with OkHttp
import okhttp3.*;
OkHttpClient client = new OkHttpClient();
Request.Builder requestBuilder = new Request.Builder()
    .url(url)
    .get();
// Add auth headers
    requestBuilder.addHeader(header.getKey(), header.getValue());
Response response = client.newCall(requestBuilder.build()).execute();
Example 7: Using with Spring RestTemplate
import org.springframework.http.*;
import org.springframework.web.client.RestTemplate;
Map<String, String> authHeaders = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "GET", url, null);
RestTemplate restTemplate = new RestTemplate();
HttpHeaders headers = new HttpHeaders();
// Add auth headers
authHeaders.forEach(headers::add);
HttpEntity<String> entity = new HttpEntity<>(headers);
ResponseEntity<String> response = restTemplate.exchange(url, HttpMethod.GET, entity, String.class);
API Reference
generateAuthHeaders(apiKey, method, url, body) → Map<String, String>
Parameters:
  • url (String): Full URL including protocol, host, path, and query string
  • body (String): Request body for POST/PUT requests, null for GET requests
Returns: Map with authentication headers:
    "Authorization": "SS-HMAC Credential=...",
    "X-SS-Date": "2025-11-12T14:30:00.123Z",
    "X-SS-Nonce": "uuid-v4",
    "X-SS-Alg": "SS-HMAC-SHA256-V1"
Lower-Level Functions
For advanced use cases, you can use individual static methods:
  • deriveKid(String apiKey) → String - Derives Key Identifier from API key
  • deriveHmacKey(String apiKey) → byte[] - Derives HMAC signing key using HKDF
  • buildCanonicalRequest(...) → String - Builds canonical request string
  • generateSignature(String canonicalRequest, byte[] hmacKey) → String - Generates HMAC-SHA256 signature
  • generateNonce() → String - Generates UUID v4 nonce
  • generateTimestamp() → String - Generates ISO8601 timestamp with milliseconds
Authentication Flow
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname:port
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Compiling and Running
Compile the library:
javac SafeSkyHmacAuth.java
Compile and run the example (requires Gson):
## Download Gson jar
wget https://repo1.maven.org/maven2/com/google/code/gson/gson/2.10.1/gson-2.10.1.jar
## Compile
javac -cp gson-2.10.1.jar SafeSkyHmacAuth.java SafeSkyHmacExample.java
## Run
java -cp .:gson-2.10.1.jar SafeSkyHmacExample
Using with Maven:
Add to your pom.xml:
<dependencies>
    <!-- Optional: Only needed if using Gson for JSON handling -->
    <dependency>
    </dependency>
</dependencies>
Security Notes
  • Use environment variables: Store keys in secure configuration
Troubleshooting
Invalid Signature
Check:
Replay Attack Detected
Timestamp Out of Range
Authentication Failed
Running Examples
## or update API_ENDPOINT to https://uav-api.safesky.app for production
For questions or issues:
  • Email: support@safesky.app
