HMAC Auth SDK for Java
Java SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
Click here to accessdownload the SDK
Installation
No external dependencies required for the core library! Uses only Java standard library.
Requirements:
  • Java 17+ (for text blocks and modern APIs)
<!-- For the example file only (optional), add Gson for JSON handling -->
<dependency>
    <groupId>com.google.code.gson</groupId>
    <artifactId>gson</artifactId>
    <version>2.10.1</version>
</dependency>
Quick Start
import java.util.Map;
public class QuickStart {
    public static void main(String[] args) {
        // Your SafeSky API key
        String apiKey = "YOUR_SAFESKY_API_KEY_HERE";
        Map<String, String> headers = SafeSkyHmacAuth.generateAuthHeaders(
            apiKey,
            "GET",
            "https://sandbox-public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908",
            // "https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908",  // Production
            null  // body is null for GET requests
        // Use with your HTTP client
        // headers contains: Authorization, X-SS-Date, X-SS-Nonce, X-SS-Alg
Usage Examples
Example 1: GET Request (Nearby Aircraft) with HttpURLConnection
import java.net.HttpURLConnection;
import java.net.URI;
String url = "https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000";
// Generate headers
Map<String, String> headers = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "GET", url, null);
// Make request
HttpURLConnection conn = (HttpURLConnection) URI.create(url).toURL().openConnection();
conn.setRequestMethod("GET");
// Add auth headers
for (Map.Entry<String, String> header : headers.entrySet()) {
    conn.setRequestProperty(header.getKey(), header.getValue());
int statusCode = conn.getResponseCode();
// Read response...
conn.disconnect();
import com.google.gson.JsonArray;
import com.google.gson.JsonObject;
import com.google.gson.Gson;
import java.io.OutputStream;
import java.nio.charset.StandardCharsets;
String url = "https://api.safesky.app/v1/uav";
// Build JSON body
JsonArray bodyArray = new JsonArray();
JsonObject uav = new JsonObject();
uav.addProperty("id", "my_uav_001");
uav.addProperty("altitude", 110);
uav.addProperty("latitude", 50.69378);
uav.addProperty("longitude", 4.39201);
uav.addProperty("last_update", System.currentTimeMillis() / 1000);
uav.addProperty("status", "AIRBORNE");
uav.addProperty("call_sign", "Test UAV");
uav.addProperty("ground_speed", 10);
uav.addProperty("course", 250);
uav.addProperty("vertical_rate", 5);
bodyArray.add(uav);
String body = new Gson().toJson(bodyArray);
Map<String, String> headers = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "POST", url, body);
// Make request
conn.setRequestMethod("POST");
conn.setDoOutput(true);
conn.setRequestProperty("Content-Type", "application/json");
// Write body
try (OutputStream os = conn.getOutputStream()) {
    byte[] input = body.getBytes(StandardCharsets.UTF_8);
    os.write(input, 0, input.length);
conn.disconnect();
Complete Examples
The SDK includes 5 complete examples in SafeSkyHmacExample.java:
// URL includes query parameters
String url = "https://api.safesky.app/v1/uav?return_nearby_traffic=true";
String body = /* JSON body */;
// Query params are automatically included in signature
String url = "https://api.safesky.app/v1/advisory";
long timestamp = System.currentTimeMillis() / 1000;
String body = """
        "id": "advisory_001",
        "max_altitude": 111,
        "last_update": %d,
        "call_sign": "Test Advisory",
        "remarks": "Testing"
        "coordinates": [[
          [4.38, 50.69],
          [4.40, 50.69],
          [4.40, 50.70],
          [4.38, 50.70],
          [4.38, 50.69]
""".formatted(timestamp);
Example 5: Using with Apache HttpClient
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.HttpClients;
String url = "https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908";
try (CloseableHttpClient httpClient = HttpClients.createDefault()) {
    HttpGet request = new HttpGet(url);
    // Add auth headers
        request.addHeader(header.getKey(), header.getValue());
    httpClient.execute(request);
Example 6: Using with OkHttp
import okhttp3.*;
OkHttpClient client = new OkHttpClient();
Request.Builder requestBuilder = new Request.Builder()
    .url(url)
    .get();
// Add auth headers
    requestBuilder.addHeader(header.getKey(), header.getValue());
Response response = client.newCall(requestBuilder.build()).execute();
Example 7: Using with Spring RestTemplate
import org.springframework.http.*;
import org.springframework.web.client.RestTemplate;
Map<String, String> authHeaders = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "GET", url, null);
RestTemplate restTemplate = new RestTemplate();
HttpHeaders headers = new HttpHeaders();
// Add auth headers
authHeaders.forEach(headers::add);
HttpEntity<String> entity = new HttpEntity<>(headers);
ResponseEntity<String> response = restTemplate.exchange(url, HttpMethod.GET, entity, String.class);
API Reference
generateAuthHeaders(apiKey, method, url, body) → Map<String, String>
Parameters:
  • url (String): Full URL including protocol, host, path, and query string
  • body (String): Request body for POST/PUT requests, null for GET requests
Returns: Map with authentication headers:
    "Authorization": "SS-HMAC Credential=...",
    "X-SS-Date": "2025-11-12T14:30:00.123Z",
    "X-SS-Nonce": "uuid-v4",
    "X-SS-Alg": "SS-HMAC-SHA256-V1"
Lower-Level Functions
For advanced use cases, you can use individual static methods:
  • deriveKid(String apiKey) → String - Derives Key Identifier from API key
  • deriveHmacKey(String apiKey) → byte[] - Derives HMAC signing key using HKDF
  • buildCanonicalRequest(...) → String - Builds canonical request string
  • generateSignature(String canonicalRequest, byte[] hmacKey) → String - Generates HMAC-SHA256 signature
  • generateNonce() → String - Generates UUID v4 nonce
  • generateTimestamp() → String - Generates ISO8601 timestamp with milliseconds
Authentication Flow
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname:port
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Compiling and Running
Compile the library:
javac SafeSkyHmacAuth.java
Compile and run the example (requires Gson):
## Download Gson jar
wget https://repo1.maven.org/maven2/com/google/code/gson/gson/2.10.1/gson-2.10.1.jar
## Compile
javac -cp gson-2.10.1.jar SafeSkyHmacAuth.java SafeSkyHmacExample.java
## Run
java -cp .:gson-2.10.1.jar SafeSkyHmacExample
Using with Maven:
Add to your pom.xml:
<dependencies>
    <!-- Optional: Only needed if using Gson for JSON handling -->
    <dependency>
    </dependency>
</dependencies>
Security Notes
  • Use environment variables: Store keys in secure configuration
Troubleshooting
Invalid Signature
Check:
Replay Attack Detected
Timestamp Out of Range
Authentication Failed
Running Examples
## or update API_ENDPOINT to https://api.safesky.app for production
For questions or issues:
  • Email: support@safesky.app
