HMAC Auth SDK for C
SafeSky HMAC Authentication SDK for C
C SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
API Endpoint: All requests use https://uav-api.safesky.app. Each API key is associated with either a sandbox or production environment. The gateway automatically routes your request to the correct backend based on the environment configured for your API key.
Installation
Dependencies:
  • OpenSSL (libssl-dev, libcrypto)
  • libcurl (for HTTP requests in examples)
  • libuuid (for UUID generation on Linux)
Ubuntu/Debian
sudo apt-get install libssl-dev libcurl4-openssl-dev uuid-dev
macOS (Homebrew)
brew install openssl curl ossp-uuid
CentOS/RHEL
sudo yum install openssl-devel libcurl-devel libuuid-devel
Compilation
## Compile the library and example
gcc -o example safesky_hmac_auth.c example.c -lssl -lcrypto -lcurl -luuid
## On macOS, you might need to specify OpenSSL path:
gcc -o example safesky_hmac_auth.c example.c \
    -I/opt/homebrew/opt/openssl/include \
    -L/opt/homebrew/opt/openssl/lib \
## Run
./example
Quick Start
##include "safesky_hmac_auth.h"
int main() {
    // Your SafeSky API key
    const char* api_key = "YOUR_SAFESKY_API_KEY_HERE";
    SafeSkyAuthHeaders headers;
    safesky_generate_auth_headers(
        api_key,
        "GET",
        "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908",
        NULL,  // body is NULL for GET requests
        &headers
    // Use headers.authorization, headers.x_ss_date, etc.
    printf("Authorization: %s\n", headers.authorization);
    printf("X-SS-Date: %s\n", headers.x_ss_date);
    printf("X-SS-Nonce: %s\n", headers.x_ss_nonce);
    printf("X-SS-Alg: %s\n", headers.x_ss_alg);
    return 0;
Usage Examples
The SDK includes 4 complete examples:
Example 1: GET Request with libcurl
##include <curl/curl.h>
void get_nearby_aircraft() {
    const char* url = "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000";
    // Generate headers
    safesky_generate_auth_headers(api_key, "GET", url, NULL, &headers);
    // Setup libcurl
    CURL *curl = curl_easy_init();
    if (curl) {
        struct curl_slist *header_list = NULL;
        char auth_header[1024];
        snprintf(auth_header, sizeof(auth_header), "Authorization: %s", headers.authorization);
        header_list = curl_slist_append(header_list, auth_header);
        char date_header[256];
        snprintf(date_header, sizeof(date_header), "X-SS-Date: %s", headers.x_ss_date);
        header_list = curl_slist_append(header_list, date_header);
        char nonce_header[256];
        snprintf(nonce_header, sizeof(nonce_header), "X-SS-Nonce: %s", headers.x_ss_nonce);
        header_list = curl_slist_append(header_list, nonce_header);
        char alg_header[128];
        snprintf(alg_header, sizeof(alg_header), "X-SS-Alg: %s", headers.x_ss_alg);
        header_list = curl_slist_append(header_list, alg_header);
        curl_easy_setopt(curl, CURLOPT_URL, url);
        curl_easy_setopt(curl, CURLOPT_HTTPHEADER, header_list);
        CURLcode res = curl_easy_perform(curl);
        curl_slist_free_all(header_list);
        curl_easy_cleanup(curl);
Example 2: POST Request
void post_uav_position() {
    const char* url = "https://uav-api.safesky.app/v1/uav";
    // Build JSON body
    char body[1024];
    long timestamp = time(NULL);
    snprintf(body, sizeof(body),
        "[{\"id\":\"my_uav_001\",\"altitude\":110,\"latitude\":50.69378,"
        "\"longitude\":4.39201,\"last_update\":%ld,\"status\":\"AIRBORNE\","
        "\"call_sign\":\"Test UAV\",\"ground_speed\":10,\"course\":250,"
        "\"vertical_rate\":5}]", timestamp);
    safesky_generate_auth_headers(api_key, "POST", url, body, &headers);
    // Setup libcurl
    if (curl) {
        // Add auth headers (same as GET example)
        // ... add all headers ...
        curl_easy_setopt(curl, CURLOPT_POST, 1L);
        curl_easy_setopt(curl, CURLOPT_POSTFIELDS, body);
void post_advisory() {
    const char* url = "https://uav-api.safesky.app/v1/advisory";
    // Build GeoJSON FeatureCollection with polygon and point
    char body[8192];
        "{\"type\":\"FeatureCollection\",\"features\":["
        "{\"type\":\"Feature\",\"properties\":{"
        "\"id\":\"my_advisory_id1\",\"max_altitude\":111,\"last_update\":%ld,"
        "\"call_sign\":\"Advisory test with polygon\",\"remarks\":\"Inspection powerlines\"},"
        "\"geometry\":{\"type\":\"Polygon\",\"coordinates\":[["
        "[4.3948,50.6831],[4.3952,50.6832],[4.3958,50.6835],"
        "/* ... more coordinates ... */"
        "[4.3948,50.6831]"
        "\"id\":\"my_advisory_id2\",\"max_altitude\":150,\"max_distance\":500,"
        "\"last_update\":%ld,\"call_sign\":\"Advisory test with a point\","
        "\"remarks\":\"Inspection rails\"},"
        "\"geometry\":{\"type\":\"Point\",\"coordinates\":[4.4,50.7]}}"
        "]}", timestamp, timestamp);
    // Make request with libcurl (similar to Example 2)
void manual_authentication() {
    // Step 1: Derive KID
    char kid[64];
    safesky_derive_kid(api_key, kid);
    printf("KID: %s\n", kid);
    // Step 2: Derive HMAC key
    unsigned char hmac_key[32];
    safesky_derive_hmac_key(api_key, hmac_key);
    char timestamp[64], nonce[64];
    safesky_generate_timestamp(timestamp);
    safesky_generate_nonce(nonce);
    char canonical[4096];
    safesky_build_canonical_request(
        "GET", "/v1/uav", "lat=50.6970&lng=4.3908",
        "api.safesky.app", timestamp, nonce, "",
        canonical
    // Step 5: Generate signature
    char signature[256];
    safesky_generate_signature(canonical, hmac_key, signature);
    printf("Signature: %s\n", signature);
API Reference
Main Function
safesky_generate_auth_headers()
void safesky_generate_auth_headers(
    const char* api_key,           // Your SafeSky API key
    const char* method,            // HTTP method (GET, POST, etc.)
    const char* url,               // Full URL with protocol and query string
    const char* body,              // Request body (NULL for GET)
    SafeSkyAuthHeaders* headers_out // Output structure
SafeSkyAuthHeaders structure:
typedef struct {
    char authorization[512];  // Authorization header
    char x_ss_date[64];      // X-SS-Date header
    char x_ss_nonce[64];     // X-SS-Nonce header
    char x_ss_alg[32];       // X-SS-Alg header
} SafeSkyAuthHeaders;
Lower-Level Functions
For advanced use cases:
  • safesky_derive_kid(api_key, kid_out) - Derives Key Identifier
  • safesky_derive_hmac_key(api_key, hmac_key_out) - Derives HMAC signing key
  • safesky_build_canonical_request(...) - Builds canonical request string
  • safesky_generate_signature(canonical_request, hmac_key, signature_out) - Generates signature
  • safesky_generate_nonce(nonce_out) - Generates UUID v4 nonce
  • safesky_generate_timestamp(timestamp_out) - Generates ISO8601 timestamp
Authentication Flow
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname:port
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Makefile Example
Create a Makefile for easier compilation:
CC = gcc
CFLAGS = -Wall -O2
LIBS = -lssl -lcrypto -lcurl -luuid
## macOS specific
ifeq ($(shell uname), Darwin)
    CFLAGS += -I/opt/homebrew/opt/openssl/include
    LIBS += -L/opt/homebrew/opt/openssl/lib
endif
all: example
example: safesky_hmac_auth.c example.c
	$(CC) $(CFLAGS) -o example safesky_hmac_auth.c example.c $(LIBS)
clean:
	rm -f example *.o
.PHONY: all clean
Then simply run:
make
./example
Security Notes
  • Use environment variables: Store keys securely
  • Memory safety: Always allocate sufficient buffer sizes for outputs
Troubleshooting
Compilation Errors
OpenSSL not found:
## Ubuntu/Debian
## macOS
export CFLAGS="-I/opt/homebrew/opt/openssl/include"
export LDFLAGS="-L/opt/homebrew/opt/openssl/lib"
libcurl not found:
## Ubuntu/Debian
sudo apt-get install libcurl4-openssl-dev
## macOS
brew install curl
libuuid not found (Linux):
sudo apt-get install uuid-dev
Runtime Errors
Invalid Signature:
Replay Attack Detected:
Timestamp Out of Range:
Running Examples
## Compile
## or update API_ENDPOINT to https://uav-api.safesky.app for production
./example
For questions or issues:
  • Email: support@safesky.app
