HMAC Auth SDK for C#
C# SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
Installation
.NET 8.0+
Add the SDK files to your project:
  • SafeSkyHmacAuth.cs - Core authentication library
  • Program.cs - Example usage (optional)
No external dependencies required - uses only built-in .NET libraries.
NuGet Package (if published)
dotnet add package SafeSky.HmacAuth
Quick Start
using System;
using System.Net.Http;
using System.Threading.Tasks;
using SafeSky.Authentication;
class Program
    static async Task Main()
        // Your SafeSky API key
        const string apiKey = "YOUR_SAFESKY_API_KEY_HEREHere";
        var headers = SafeSkyHmacAuth.GenerateAuthHeaders(
            apiKey,
            "GET",
            "https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908"
        // Make authenticated request
        using var client = new HttpClient();
        var request = new HttpRequestMessage(HttpMethod.Get,
            "https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908");
        foreach (var header in headers.ToDictionary())
            request.Headers.Add(header.Key, header.Value);
        var response = await client.SendAsync(request);
        var content = await response.Content.ReadAsStringAsync();
        Console.WriteLine(content);
Usage Examples
The SDK includes 4 complete examples in Program.cs:
Example 1: GET Request
using System;
async Task GetNearbyAircraft()
    const string apiKey = "YOUR_SAFESKY_API_KEY_HERE";
    const string url = "https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000";
    // Generate auth headers
    var authHeaders = SafeSkyHmacAuth.GenerateAuthHeaders(apiKey, "GET", url);
    // Make request
    var request = new HttpRequestMessage(HttpMethod.Get, url);
    foreach (var header in authHeaders.ToDictionary())
    request.Headers.Add("Content-Type", "application/json");
    Console.WriteLine($"Status: {(int)response.StatusCode}");
Example 2: POST Request
using System;
using System.Text;
using System.Text.Json;
async Task PostUavPosition()
    const string url = "https://api.safesky.app/v1/uav";
    // Build request body
    var bodyData = new[]
        new
            id = "my_uav_001",
            altitude = 110,
            latitude = 50.69378,
            longitude = 4.39201,
            last_update = DateTimeOffset.UtcNow.ToUnixTimeSeconds(),
            status = "AIRBORNE",
            call_sign = "Test UAV",
            ground_speed = 10,
            course = 250,
            vertical_rate = 5
    var body = JsonSerializer.Serialize(bodyData);
    var authHeaders = SafeSkyHmacAuth.GenerateAuthHeaders(apiKey, "POST", url, body);
    // Make request
    var request = new HttpRequestMessage(HttpMethod.Post, url)
        Content = new StringContent(body, Encoding.UTF8, "application/json")
using System;
using System.Text;
async Task PostAdvisory()
    const string url = "https://api.safesky.app/v1/advisory";
    var timestamp = DateTimeOffset.UtcNow.ToUnixTimeSeconds();
    var bodyData = new
        type = "FeatureCollection",
        features = new object[]
            new
                type = "Feature",
                properties = new
                    id = "my_advisory_id1",
                    max_altitude = 111,
                    last_update = timestamp,
                    call_sign = "Advisory test with polygon",
                    remarks = "Inspection powerlines"
                geometry = new
                    type = "Polygon",
                    coordinates = new[]
                        new[]
                            new[] { 4.3948, 50.6831 }, new[] { 4.3952, 50.6832 },
                            // ... more coordinates ...
            new
                type = "Feature",
                properties = new
                    id = "my_advisory_id2",
                    max_altitude = 150,
                    max_distance = 500,
                    call_sign = "Advisory test with a point",
                    remarks = "Inspection rails"
                geometry = new
                    type = "Point",
                    coordinates = new[] { 4.4, 50.7 }
using System;
using System.Linq;
void ManualAuthentication()
    // Step 1: Derive KID
    var kid = SafeSkyHmacAuth.DeriveKid(apiKey);
    Console.WriteLine($"KID: {kid}");
    // Step 2: Derive HMAC key
    var hmacKey = SafeSkyHmacAuth.DeriveHmacKey(apiKey);
    var timestamp = SafeSkyHmacAuth.GenerateTimestamp();
    var nonce = SafeSkyHmacAuth.GenerateNonce();
    var canonicalRequest = SafeSkyHmacAuth.BuildCanonicalRequest(
        "GET",
        "/v1/uav",
        "lat=50.6970&lng=4.3908",
        "api.safesky.app",
        timestamp,
        nonce,
    // Step 5: Generate signature
    var signature = SafeSkyHmacAuth.GenerateSignature(canonicalRequest, hmacKey);
    Console.WriteLine($"Signature: {signature}");
API Reference
Main Class: SafeSkyHmacAuth
Static class providing HMAC authentication functions.
######## GenerateAuthHeaders(apiKey, method, url, body = "")
Parameters:
Returns: SafeSkyAuthHeaders containing all required headers
    "YOUR_SAFESKY_API_KEY_HERE",
    "POST",
    "https://api.safesky.app/v1/uav",
    JsonSerializer.Serialize(data)
SafeSkyAuthHeaders Class
Container for authentication headers.
Properties:
  • Authorization (string): Authorization header value
  • XSsDate (string): X-SS-Date header value
  • XSsNonce (string): X-SS-Nonce header value
  • XSsAlg (string): X-SS-Alg header value
Methods:
  • ToDictionary() → Dictionary<string, string>: Convert headers to dictionary for HTTP requests
Helper Methods
######## DeriveKid(apiKey) → string
######## DeriveHmacKey(apiKey) → byte[]
######## GenerateNonce() → string
Generates a cryptographically secure nonce (GUID format).
######## GenerateTimestamp() → string
Format: yyyy-MM-ddTHH:mm:ss.fffZ
######## BuildCanonicalRequest(...) → string
Parameters:
  • path (string): Request path
  • body (string): Request body
######## GenerateSignature(canonicalRequest, hmacKey) → string
Authentication Flow
  3. Generate Nonce: GUID for replay protection
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname:port
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Running Examples
## Build and run
dotnet run
## Build only
dotnet build
## Run with specific runtime
dotnet run --framework net8.0
Framework Support
  • .NET 8.0+ (recommended)
  • .NET 6.0+ (compatible)
  • .NET Core 3.1+ (compatible)
  • .NET Framework 4.7.2+ (compatible with minor modifications)
ASP.NET Core Integration
using Microsoft.AspNetCore.Mvc;
[ApiController]
[Route("api/[controller]")]
public class SafeSkyController : ControllerBase
    private readonly string _apiKey;
    private readonly HttpClient _httpClient;
    public SafeSkyController(IConfiguration config, IHttpClientFactory httpClientFactory)
        _apiKey = config["SafeSky:ApiKey"];
        _httpClient = httpClientFactory.CreateClient();
    [HttpGet("aircraft")]
    public async Task<IActionResult> GetNearbyAircraft(double lat, double lng)
        var url = $"https://api.safesky.app/v1/uav?lat={lat}&lng={lng}&rad=20000";
        var headers = SafeSkyHmacAuth.GenerateAuthHeaders(_apiKey, "GET", url);
        var response = await _httpClient.SendAsync(request);
        return Content(content, "application/json");
Security Notes
  • Use configuration: Store keys in appsettings.json, environment variables, or Azure Key Vault
Troubleshooting
Invalid Signature
Replay Attack Detected
Timestamp Out of Range
Dependencies
  • System.Security.Cryptography - Built-in (SHA-256, HMAC)
  • System.Net.Http - Built-in (HTTP client)
  • System.Text.Json - Built-in for .NET 8.0+ (JSON serialization in examples)
For questions or issues:
  • Email: support@safesky.app
