HMAC Auth for Node.js
Single Endpoint: All requests use https://uav-api.safesky.app regardless of environment. Your API key determines whether requests are routed to sandbox or production. Each API key is associated with either a sandbox or production environment, and the gateway automatically routes your request to the correct backend.
Installation
# Copy the SDK to your project
cp safesky-hmac-auth.js /path/to/your/project/
Requirements:
  • Node.js 16+
Quick Start
const safeskyAuth = require('./safesky-hmac-auth');
const API_KEY = 'YOUR_SAFESKY_API_KEY_HERE';
    API_KEY,
    'GET',
    'https://sandbox-public-uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'
    // 'https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'  // Production
console.log(headers);
//   'Authorization': 'SS-HMAC Credential=xxx/v1, SignedHeaders=host;x-ss-date;x-ss-nonce, Signature=yyy',
//   'X-SS-Date': '2025-11-12T14:30:00Z',
//   'X-SS-Nonce': '550e8400-e29b-41d4-a716-446655440000',
//   'X-SS-Alg': 'SS-HMAC-SHA256-V1'
API Reference
Parameters:
    'YOUR_SAFESKY_API_KEY_HERE',
    'POST',
    'https://sandbox-public-uav-api.safesky.app/v1/uav',
    // 'https://public-api.safesky.app/v1/uav',  // Production
deriveKid(apiKey)
Parameters:
deriveHmacKey(apiKey)
Parameters:
generateNonce()
generateTimestamp()
Parameters:
  • path (string): Request path
  • body (string): Request body
Parameters:
  • hmacKey (Buffer): The derived HMAC signing key
Complete Examples
Example 1: GET Request
const url = 'https://sandbox-public-uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000';
// const url = 'https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000';  // Production
// Generate auth headers
// Make request
const urlObj = new URL(url);
const options = {
    hostname: urlObj.hostname,
    method: 'GET',
    headers: {
        ...authHeaders,
https.get(options, (res) => {
    let data = '';
Example 2: POST Request
const url = 'https://sandbox-public-uav-api.safesky.app/v1/uav';
// const url = 'https://public-api.safesky.app/v1/uav';  // Production
    altitude: 110,
    latitude: 50.69378,
    longitude: 4.39201,
    status: 'AIRBORNE',
    call_sign: 'Test UAV'
// Make request
const options = {
    path: urlObj.pathname,
    method: 'POST',
    headers: {
        ...authHeaders,
    let data = '';
req.write(body);
req.end();
const url = 'https://sandbox-public-uav-api.safesky.app/v1/advisory';
// const url = 'https://public-api.safesky.app/v1/advisory';  // Production
const body = JSON.stringify({
    type: "FeatureCollection",
    features: [
            type: "Feature",
            properties: {
                max_altitude: 111,
            geometry: {
                type: "Polygon",
            type: "Feature",
            properties: {
                max_altitude: 150,
                max_distance: 500,
                remarks: "Inspection rails"
            geometry: {
                type: "Point",
                coordinates: [4.4, 50.7]
Example 4: Using with Axios
        headers: {
            ...authHeaders,
    return response.data;
getNearbyAircraft()
async function publishUAV() {
        altitude: 110,
        latitude: 50.69378,
        longitude: 4.39201,
        method: 'POST',
        headers: {
            ...authHeaders,
        body: body
    return await response.json();
publishUAV()
Running Examples
## Run the provided example file
node example.js
Security Notes
  1. Keep your API key secret - Never commit it to version control or expose it in client-side code
  2. Use environment variables - Store your API key in environment variables:
    const API_KEY = process.env.SAFESKY_API_KEY;
  3. Use HTTPS only - The SafeSky API only accepts HTTPS requests
  4. Handle errors - Always implement proper error handling in production code
How It Works
  1. Derive KID: A public identifier is derived from your API key
  2. Derive HMAC Key: A signing key is derived using HKDF-SHA256
  3. Build Canonical Request: A standardized string representation of the request
  4. Generate Signature: HMAC-SHA256 signature of the canonical request
  5. Set Headers: Add Authorization, X-SS-Date, X-SS-Nonce, and X-SS-Alg headers
This ensures:
  • Authentication: Only holders of valid API keys can make requests
  • Integrity: Request data cannot be modified in transit
  • Replay Protection: Each request uses a unique nonce and timestamp
Troubleshooting
"Invalid signature" error
  • Ensure your API key is correct
  • Verify the request URL, method, and body exactly match what you're signing
  • Check that the timestamp is within ±5 minutes of server time
  • Don't reuse the same nonce within the validity window
  • Generate a fresh nonce for each request using generateNonce()
"Clock skew too large" error
  • Ensure your system clock is synchronized
  • The timestamp must be within ±5 minutes of the server time
For questions or issues:
  • Email: support@safesky.app
