HMAC Auth for Node.js
Installation
## Copy the SDK to your project
cp safesky-hmac-auth.js /path/to/your/project/
Requirements:
- Node.js 16+
Quick Start
const safeskyAuth = require('./safesky-hmac-auth');
const API_KEY = 'YOUR_SAFESKY_API_KEY_HERE';
API_KEY,
'GET',
'https://sandbox-public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'
// 'https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908' // Production
console.log(headers);
// 'Authorization': 'SS-HMAC Credential=xxx/v1, SignedHeaders=host;x-ss-date;x-ss-nonce, Signature=yyy',
// 'X-SS-Date': '2025-11-12T14:30:00Z',
// 'X-SS-Nonce': '550e8400-e29b-41d4-a716-446655440000',
// 'X-SS-Alg': 'SS-HMAC-SHA256-V1'
######## API Reference
############ generateAuthHeaders(apiKey, method, url, body = '')
Parameters:
apiKey(string): Your SafeSky API key (e.g.,ssk_live_...)method(string): HTTP method (GET,POST, etc.)url(string): Full request URL including protocol, host, path, and query stringbody(string, optional): Request body for POST/PUT requests (default: empty string)
'YOUR_SAFESKY_API_KEY_HERE',
'POST',
'https://sandbox-public-api.safesky.app/v1/uav',
// 'https://public-api.safesky.app/v1/uav', // Production
############ deriveKid(apiKey)
Parameters:
############ deriveHmacKey(apiKey)
Parameters:
############ generateNonce()
############ generateTimestamp()
############ buildCanonicalRequest(method, path, queryString, host, timestamp, nonce, body)
Parameters:
method(string): HTTP methodpath(string): Request pathqueryString(string): Query string without leading?host(string): Host header valuetimestamp(string): ISO8601 timestampnonce(string): Unique noncebody(string): Request body
############ generateSignature(canonicalRequest, hmacKey)
Parameters:
canonicalRequest(string): The canonical request stringhmacKey(Buffer): The derived HMAC signing key
######## Complete Examples
- POST UAV with query parameters - Submit UAV and get nearby traffic
############ Example 1: GET Request
const url = 'https://sandbox-public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000';
// const url = 'https://public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000'; // Production
// Generate auth headers
// Make request
const urlObj = new URL(url);
const options = {
hostname: urlObj.hostname,
method: 'GET',
headers: {
...authHeaders,
https.get(options, (res) => {
let data = '';
############ Example 2: POST Request
const url = 'https://sandbox-public-api.safesky.app/v1/uav';
// const url = 'https://public-api.safesky.app/v1/uav'; // Production
altitude: 110,
latitude: 50.69378,
longitude: 4.39201,
status: 'AIRBORNE',
call_sign: 'Test UAV'
// Make request
const options = {
path: urlObj.pathname,
method: 'POST',
headers: {
...authHeaders,
let data = '';
req.write(body);
req.end();
############ Example 3: POST Advisory (GeoJSON)
const url = 'https://sandbox-public-api.safesky.app/v1/advisory';
// const url = 'https://public-api.safesky.app/v1/advisory'; // Production
const body = JSON.stringify({
type: "FeatureCollection",
features: [
type: "Feature",
properties: {
max_altitude: 111,
geometry: {
type: "Polygon",
type: "Feature",
properties: {
max_altitude: 150,
max_distance: 500,
remarks: "Inspection rails"
geometry: {
type: "Point",
coordinates: [4.4, 50.7]
############ Example 4: Using with Axios
headers: {
...authHeaders,
return response.data;
getNearbyAircraft()
############ Example 5: Using with Fetch API
async function publishUAV() {
altitude: 110,
latitude: 50.69378,
longitude: 4.39201,
method: 'POST',
headers: {
...authHeaders,
body: body
return await response.json();
publishUAV()
######## Running Examples
#### Run the provided example file
node example.js
######## Security Notes
- Keep your API key secret - Never commit it to version control or expose it in client-side code
- Use environment variables - Store your API key in environment variables:
const API_KEY = process.env.SAFESKY_API_KEY; - Use HTTPS only - The SafeSky API only accepts HTTPS requests
- Handle errors - Always implement proper error handling in production code
######## How It Works
- Derive KID: A public identifier is derived from your API key
- Derive HMAC Key: A signing key is derived using HKDF-SHA256
- Build Canonical Request: A standardized string representation of the request
- Generate Signature: HMAC-SHA256 signature of the canonical request
- Set Headers: Add Authorization, X-SS-Date, X-SS-Nonce, and X-SS-Alg headers
This ensures:
- Authentication: Only holders of valid API keys can make requests
- Integrity: Request data cannot be modified in transit
- Replay Protection: Each request uses a unique nonce and timestamp
######## Troubleshooting
############ "Invalid signature" error
- Ensure your API key is correct
- Verify the request URL, method, and body exactly match what you're signing
- Check that the timestamp is within ±5 minutes of server time
############ "Replay attack detected" error
- Don't reuse the same nonce within the validity window
- Generate a fresh nonce for each request using
generateNonce()
############ "Clock skew too large" error
- Ensure your system clock is synchronized
- The timestamp must be within ±5 minutes of the server time
######## Support
For questions or issues:
- Email: support@safesky.app
