HMAC Authentication for Node.js
Quick Start
const safeskyAuth = require('./index');
// Your SafeSky API key
const API_KEY = 'ssk_live_YourApiKeyHere';
API_KEY,
'GET',
'https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'
console.log(headers);
// 'Authorization': 'SS-HMAC Credential=xxx/v1, SignedHeaders=host;x-ss-date;x-ss-nonce, Signature=yyy',
// 'X-SS-Date': '2025-11-12T14:30:00Z',
// 'X-SS-Nonce': '550e8400-e29b-41d4-a716-446655440000',
// 'X-SS-Alg': 'SS-HMAC-SHA256-V1'
API Reference
Parameters:
apiKey(string): Your SafeSky API key (e.g.,ssk_live_...)method(string): HTTP method (GET,POST, etc.)url(string): Full request URL including protocol, host, path, and query stringbody(string, optional): Request body for POST/PUT requests (default: empty string)
'ssk_live_YourApiKey',
'POST',
'https://api.safesky.app/v1/uav',
deriveKid(apiKey)
Parameters:
deriveHmacKey(apiKey)
Parameters:
generateNonce()
generateTimestamp()
Parameters:
method(string): HTTP methodpath(string): Request pathqueryString(string): Query string without leading?host(string): Host header valuetimestamp(string): ISO8601 timestampnonce(string): Unique noncebody(string): Request body
Parameters:
canonicalRequest(string): The canonical request stringhmacKey(Buffer): The derived HMAC signing key
Complete Examples
- POST UAV with query parameters - Submit UAV and get nearby traffic
Example 1: GET Request
const API_KEY = 'ssk_live_YourApiKey';
const url = 'https://api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000';
// Generate auth headers
// Make request
const urlObj = new URL(url);
const options = {
hostname: urlObj.hostname,
method: 'GET',
headers: {
...authHeaders,
https.get(options, (res) => {
let data = '';
Example 2: POST Request
const url = 'https://api.safesky.app/v1/uav';
altitude: 110,
latitude: 50.69378,
longitude: 4.39201,
status: 'AIRBORNE',
call_sign: 'Test UAV'
// Make request
const options = {
path: urlObj.pathname,
method: 'POST',
headers: {
...authHeaders,
let data = '';
req.write(body);
req.end();
const url = 'https://api.safesky.app/v1/advisory';
const body = JSON.stringify({
type: "FeatureCollection",
features: [
type: "Feature",
properties: {
max_altitude: 111,
geometry: {
type: "Polygon",
type: "Feature",
properties: {
max_altitude: 150,
max_distance: 500,
remarks: "Inspection rails"
geometry: {
type: "Point",
coordinates: [4.4, 50.7]
Example 4: Using with Axios
headers: {
...authHeaders,
return response.data;
getNearbyAircraft()
async function publishUAV() {
altitude: 110,
latitude: 50.69378,
longitude: 4.39201,
method: 'POST',
headers: {
...authHeaders,
body: body
return await response.json();
publishUAV()
Running Examples
# Run the provided example file
node example.js
Security Notes
- Keep your API key secret - Never commit it to version control or expose it in client-side code
- Use environment variables - Store your API key in environment variables:
const API_KEY = process.env.SAFESKY_API_KEY; - Use HTTPS only - The SafeSky API only accepts HTTPS requests
- Handle errors - Always implement proper error handling in production code
How It Works
- Derive KID: A public identifier is derived from your API key
- Derive HMAC Key: A signing key is derived using HKDF-SHA256
- Build Canonical Request: A standardized string representation of the request
- Generate Signature: HMAC-SHA256 signature of the canonical request
- Set Headers: Add Authorization, X-SS-Date, X-SS-Nonce, and X-SS-Alg headers
This ensures:
- Authentication: Only holders of valid API keys can make requests
- Integrity: Request data cannot be modified in transit
- Replay Protection: Each request uses a unique nonce and timestamp
Troubleshooting
"Invalid signature" error
- Ensure your API key is correct
- Verify the request URL, method, and body exactly match what you're signing
- Check that the timestamp is within ±5 minutes of server time
- Don't reuse the same nonce within the validity window
- Generate a fresh nonce for each request using
generateNonce()
"Clock skew too large" error
- Ensure your system clock is synchronized
- The timestamp must be within ±5 minutes of the server time
For questions or issues:
- Email: support@safesky.app
License
MIT License - See LICENSE file for details
