HMAC Auth for GO
API Endpoint: All requests use https://uav-api.safesky.app. Each API key is associated with either a sandbox or production environment. The gateway automatically routes your request to the correct backend based on the environment configured for your API key.
Installation
# Copy the SDK to your project
cp safesky_hmac_auth.go /path/to/your/project/
Requirements:
  • Go 1.18+
Quick Start
package main
import (
    "fmt"
    "net/http"
// Import the SDK (copy safesky_hmac_auth.go to your project)
func main() {
    apiKey := "YOUR_SAFESKY_API_KEY_HERE"
    headers, err := GenerateAuthHeaders(
        apiKey,
        "GET",
        "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908",
        "", // Empty body for GET requests
    if err != nil {
        panic(err)
    fmt.Println(headers.ToMap())
    // map[Authorization:SS-HMAC Credential=xxx/v1, SignedHeaders=host;x-ss-date;x-ss-nonce, Signature=yyy
    //     X-SS-Date:2025-11-12T14:30:00.123Z
    //     X-SS-Nonce:550e8400-e29b-41d4-a716-446655440000
    //     X-SS-Alg:SS-HMAC-SHA256-V1]
API Reference
GenerateAuthHeaders(apiKey, method, url, body string) (*AuthHeaders, error)
Parameters:
  • body (string): Request body for POST/PUT requests (empty string for GET)
Returns: *AuthHeaders struct containing all required headers, or error
    "YOUR_SAFESKY_API_KEY_HERE",
    "POST",
    "https://uav-api.safesky.app/v1/uav",
    `[{"id":"uav1","lat":50.69,"lng":4.39}]`,
DeriveKID(apiKey string) string
Parameters:
Returns: string - The derived KID in base64url format
DeriveHMACKey(apiKey string) []byte
Parameters:
Returns: []byte - The derived HMAC key (32 bytes)
GenerateNonce() string
Returns: string - A UUID v4 nonce
GenerateTimestamp() string
Returns: string - ISO8601 timestamp (e.g., 2025-11-12T14:30:00.123Z)
BuildCanonicalRequest(method, path, queryString, host, timestamp, nonce, body string) string
Parameters:
  • path (string): Request path
Returns: string - The canonical request string
GenerateSignature(canonicalRequest string, hmacKey []byte) string
Parameters:
  • hmacKey ([]byte): The derived HMAC signing key
Returns: string - The signature in base64 format
AuthHeaders Struct
The AuthHeaders struct contains all authentication headers:
type AuthHeaders struct {
    Authorization string  // The full Authorization header
    XSSDate       string  // X-SS-Date header (timestamp)
    XSSNonce      string  // X-SS-Nonce header (unique nonce)
    XSSAlg        string  // X-SS-Alg header (algorithm identifier)
Use ToMap() to convert to a map[string]string for easy use with HTTP clients.
Complete Examples
The SDK includes 5 complete examples in example.go:
Run examples with:
go run example.go safesky_hmac_auth.go
Example 1: GET Request
package main
import (
    "fmt"
    "io"
    "net/http"
    "time"
func main() {
    url := "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000"
    // Generate auth headers
    authHeaders, err := GenerateAuthHeaders(apiKey, "GET", url, "")
    if err != nil {
        panic(err)
    // Create request
    req, _ := http.NewRequest("GET", url, nil)
    // Add headers
    for key, value := range authHeaders.ToMap() {
        req.Header.Set(key, value)
    req.Header.Set("Content-Type", "application/json")
    // Execute
    client := &http.Client{Timeout: 30 * time.Second}
    resp, err := client.Do(req)
    if err != nil {
        panic(err)
    defer resp.Body.Close()
    body, _ := io.ReadAll(resp.Body)
    fmt.Printf("Status: %d\n", resp.StatusCode)
    fmt.Printf("Body: %s\n", string(body))
Example 2: POST Request
package main
import (
    "bytes"
    "encoding/json"
    "fmt"
    "io"
    "net/http"
    "time"
type UAVPosition struct {
    ID           string  `json:"id"`
    Latitude     float64 `json:"latitude"`
    Longitude    float64 `json:"longitude"`
    Altitude     int     `json:"altitude"`
    GroundSpeed  int     `json:"ground_speed"`
    Status       string  `json:"status"`
    LastUpdate   int64   `json:"last_update"`
    CallSign     string  `json:"call_sign"`
    Course       int     `json:"course"`
    VerticalRate int     `json:"vertical_rate"`
func main() {
    url := "https://uav-api.safesky.app/v1/uav"
    // Create UAV data
    uavData := []UAVPosition{{
        Latitude:     50.69378,
        Longitude:    4.39201,
        Altitude:     110,
        GroundSpeed:  10,
        Status:       "AIRBORNE",
        LastUpdate:   time.Now().Unix(),
        CallSign:     "Test UAV",
        Course:       250,
        VerticalRate: 5,
    bodyBytes, _ := json.Marshal(uavData)
    bodyStr := string(bodyBytes)
    // Generate auth headers with body
    authHeaders, err := GenerateAuthHeaders(apiKey, "POST", url, bodyStr)
    if err != nil {
        panic(err)
    // Create request
    req, _ := http.NewRequest("POST", url, bytes.NewBufferString(bodyStr))
    // Add headers
    // Execute
    if err != nil {
        panic(err)
    respBody, _ := io.ReadAll(resp.Body)
    fmt.Printf("Body: %s\n", string(respBody))
Error Handling
The GenerateAuthHeaders function returns an error if the URL is invalid:
headers, err := GenerateAuthHeaders(apiKey, "GET", "invalid-url", "")
if err != nil {
    log.Fatalf("Failed to generate headers: %v", err)
Thread Safety
All functions in this SDK are stateless and thread-safe. They can be called concurrently from multiple goroutines.
Security Notes
  • Keep your API key secure and never commit it to version control
  • Use environment variables or secure configuration for API keys
  • The SDK uses cryptographically secure random number generation for nonces
  • All cryptographic operations use Go's standard library crypto packages
