HMAC Auth for GO
Installation
# Copy the SDK to your project
cp safesky_hmac_auth.go /path/to/your/project/
Requirements:
Quick Start
package main
import (
"fmt"
"net/http"
// Import the SDK (copy safesky_hmac_auth.go to your project)
func main() {
apiKey := "YOUR_SAFESKY_API_KEY_HERE"
headers, err := GenerateAuthHeaders(
apiKey,
"GET",
"https://sandbox-public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908",
"", // Empty body for GET requests
if err != nil {
panic(err)
fmt.Println(headers.ToMap())
// map[Authorization:SS-HMAC Credential=xxx/v1, SignedHeaders=host;x-ss-date;x-ss-nonce, Signature=yyy
// X-SS-Date:2025-11-12T14:30:00.123Z
// X-SS-Nonce:550e8400-e29b-41d4-a716-446655440000
// X-SS-Alg:SS-HMAC-SHA256-V1]
API Reference
GenerateAuthHeaders(apiKey, method, url, body string) (*AuthHeaders, error)
Parameters:
apiKey (string): Your SafeSky API key (e.g., ssk_live_...)
method (string): HTTP method (GET, POST, etc.)
url (string): Full request URL including protocol, host, path, and query string
body (string): Request body for POST/PUT requests (empty string for GET)
Returns: *AuthHeaders struct containing all required headers, or error
"YOUR_SAFESKY_API_KEY_HERE",
"POST",
"https://sandbox-public-api.safesky.app/v1/uav",
`[{"id":"uav1","lat":50.69,"lng":4.39}]`,
DeriveKID(apiKey string) string
Parameters:
Returns: string - The derived KID in base64url format
DeriveHMACKey(apiKey string) []byte
Parameters:
Returns: []byte - The derived HMAC key (32 bytes)
GenerateNonce() string
Returns: string - A UUID v4 nonce
GenerateTimestamp() string
Returns: string - ISO8601 timestamp (e.g., 2025-11-12T14:30:00.123Z)
BuildCanonicalRequest(method, path, queryString, host, timestamp, nonce, body string) string
Parameters:
path (string): Request path
queryString (string): Query string without leading ?
host (string): Host header value
timestamp (string): ISO8601 timestamp
nonce (string): Unique nonce
Returns: string - The canonical request string
GenerateSignature(canonicalRequest string, hmacKey []byte) string
Parameters:
canonicalRequest (string): The canonical request string
hmacKey ([]byte): The derived HMAC signing key
Returns: string - The signature in base64 format
AuthHeaders Struct
The AuthHeaders struct contains all authentication headers:
type AuthHeaders struct {
Authorization string // The full Authorization header
XSSDate string // X-SS-Date header (timestamp)
XSSNonce string // X-SS-Nonce header (unique nonce)
XSSAlg string // X-SS-Alg header (algorithm identifier)
Use ToMap() to convert to a map[string]string for easy use with HTTP clients.
Complete Examples
The SDK includes 5 complete examples in example.go:
Run examples with:
go run example.go safesky_hmac_auth.go
Example 1: GET Request
package main
import (
"fmt"
"io"
"net/http"
"time"
func main() {
url := "https://sandbox-public-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000"
// Generate auth headers
authHeaders, err := GenerateAuthHeaders(apiKey, "GET", url, "")
if err != nil {
panic(err)
// Create request
req, _ := http.NewRequest("GET", url, nil)
// Add headers
for key, value := range authHeaders.ToMap() {
req.Header.Set(key, value)
req.Header.Set("Content-Type", "application/json")
// Execute
client := &http.Client{Timeout: 30 * time.Second}
resp, err := client.Do(req)
if err != nil {
panic(err)
defer resp.Body.Close()
body, _ := io.ReadAll(resp.Body)
fmt.Printf("Status: %d\n", resp.StatusCode)
fmt.Printf("Body: %s\n", string(body))
Example 2: POST Request
package main
import (
"bytes"
"encoding/json"
"fmt"
"io"
"net/http"
"time"
type UAVPosition struct {
ID string `json:"id"`
Latitude float64 `json:"latitude"`
Longitude float64 `json:"longitude"`
Altitude int `json:"altitude"`
GroundSpeed int `json:"ground_speed"`
Status string `json:"status"`
LastUpdate int64 `json:"last_update"`
CallSign string `json:"call_sign"`
Course int `json:"course"`
VerticalRate int `json:"vertical_rate"`
func main() {
url := "https://sandbox-public-api.safesky.app/v1/uav"
// Create UAV data
uavData := []UAVPosition{{
Latitude: 50.69378,
Longitude: 4.39201,
Altitude: 110,
GroundSpeed: 10,
Status: "AIRBORNE",
LastUpdate: time.Now().Unix(),
CallSign: "Test UAV",
Course: 250,
VerticalRate: 5,
bodyBytes, _ := json.Marshal(uavData)
bodyStr := string(bodyBytes)
// Generate auth headers with body
authHeaders, err := GenerateAuthHeaders(apiKey, "POST", url, bodyStr)
if err != nil {
panic(err)
// Create request
req, _ := http.NewRequest("POST", url, bytes.NewBufferString(bodyStr))
// Add headers
// Execute
if err != nil {
panic(err)
respBody, _ := io.ReadAll(resp.Body)
fmt.Printf("Body: %s\n", string(respBody))
Error Handling
The GenerateAuthHeaders function returns an error if the URL is invalid:
headers, err := GenerateAuthHeaders(apiKey, "GET", "invalid-url", "")
if err != nil {
log.Fatalf("Failed to generate headers: %v", err)
Thread Safety
All functions in this SDK are stateless and thread-safe. They can be called concurrently from multiple goroutines.
