Enabling a 30-Day Free Trial for Your Customers
SafeSky UAV API, Enabling a 30-Day Free Trial for Your Customers
  • Product & business owners, start with the Why section to understand what the trial unlocks for your platform and your customers.
  • Developers, jump to the Integration sections for the exact headers, authentication, and trial-expiry handling you need to ship.
What Your Customers Get
  • Instant activation, no SafeSky registration, no API key, no forms.
  • Full feature access, both share (broadcast their drone positions) and receive (see surrounding manned and unmanned traffic) for the entire 30-day period.
  • Unlimited usage during the trial, the trial is time-boxed, not capped by a usage quota. For 30 days there is no minute budget, no flight-hour budget, and no throttling.
  • A seamless upgrade path, when the trial ends, customers simply paste a SafeSky API key into your configuration screen to keep receiving traffic.
What Your Platform Gets
Benefit Description
Higher adoption A one-click safety upgrade with zero onboarding friction.
Proven value before purchase 30 days of real-world experience drives conversions far better than a sales demo.
A safety story Every customer broadcasting positions makes the shared airspace safer, including for manned aviation.
No burden on you SafeSky takes care of trial provisioning, metering, and conversion.
How It Works at a Glance
│  Your Product                                                │
│   [ ON ]  Enable SafeSky Network                             │
│           Share positions + receive traffic.                 │
│           Includes a 30-day free trial.                      │
│   SafeSky API Key (optional) ........... [            ]      │
│           Add a key to keep receiving traffic after trial.   │
      Blank key field  ──►  Use embedded SafeSky integration key
      Filled key field ──►  Use the customer's own SafeSky key
                            + their own subscription
  • Field blank → your product authenticates with the integration key SafeSky issued you (a shared secret embedded in your application), and each customer runs on an automatic per-customer 30-day trial.
  • Field filled → your product authenticates with the customer's own SafeSky API key, and traffic reception is governed by their subscription.
1. Before You Begin
  • Contact SafeSky to set up a partner contract and receive your integration key, a shared secret you embed in your application. It authenticates every trial request until a customer enters their own key.
  • The integration key uses the same HMAC authentication scheme as a standard SafeSky API key (see Authentication). There is nothing new to learn about signing requests.
  • The integration key is never billed itself. It only unlocks per-customer trials when paired with an organization identifier (below).
Each of your customers (a tenant, account, workspace, or organization on your side) must be identified to SafeSky by an organization token, sent as the X-SS-Org-Id HTTP header on every request.
X-SS-Org-Id: 9f1c2e7a4b8d...
Token Requirements
Requirement Meaning Why it matters
Unique Distinct customers map to distinct token values. Two customers sharing a token would share a single trial.
Stable / immutable The same customer always produces the same token, forever. A changed token starts a brand-new trial and resets the clock.
Opaque Carries no personal data; meaningless to SafeSky. Protects your customers' privacy. A hash of the real id is encouraged.
3. Authentication Switching
Scenario Authentication X-SS-Org-Id Share positions Receive traffic
API key field blank Embedded integration key Required Unlimited 30-day trial, then empty
API key field filled Customer's own API key Optional (ignored for auth) Unlimited Subscription based
Important rules:
  • An integration key without X-SS-Org-Id is rejected with HTTP 400 Bad Request, the key may never be used anonymously, because there would be no customer to attribute the trial to.
  • When the customer enters their own key, send their key and (optionally) keep sending X-SS-Org-Id for your own analytics, SafeSky ignores it for account resolution in that case.
Once the integration key + X-SS-Org-Id are in place, the SafeSky UAV API behaves exactly like a normal paid integration. There is no special trial endpoint and no special payload.
The first request for a given X-SS-Org-Id automatically starts that customer's 30-day trial. No provisioning call, no pre-registration, the trial is created on demand on first use.
Header Example Meaning
X-SS-Trial-Status active The trial is currently running.
X-SS-Trial-Days-Remaining 15 Whole days left before expiry.
After the trial expires
Header Value Meaning
X-SS-Trial-Status (absent) No active trial.
X-SS-Trial-Days-Remaining 0 The trial has ended.
You can implement either a simple presence check (X-SS-Trial-Status present = active) or a countdown display using X-SS-Trial-Days-Remaining.
Why headers instead of dates:
  • Zero date calculations on your side.
  • SafeSky controls trial duration server-side (and can extend it remotely).
  • Works regardless of device clock settings or time zones.
  • Trivial to implement: read one header.
Endpoint Behaviour after expiry
POST /v1/uav (share positions) Continues normally. Drone safety data is never blocked.
GET /v1/uav (receive traffic) Returns HTTP 200 with an empty traffic payload and X-SS-Trial-Days-Remaining: 0.
Note: Expired GET requests return an empty 200, not an HTTP 402 error. Your integration keeps running normally, the customer simply sees "no traffic" plus the zero-days signal. This is a deliberate choice to nudge conversion rather than break your product.
  1. Detect the absence of X-SS-Trial-Status (or X-SS-Trial-Days-Remaining: 0).
  2. Show a clear notice: the trial has ended, position sharing continues, and an API key is required to keep receiving traffic.
  3. Reveal/highlight the API key field and link the customer to https://www.safesky-enterprise.com to get a key.
  4. Once a key is entered, switch authentication to the customer's own key, reception resumes immediately under their subscription.
7. Suggested User Interface
Configuration Panel
│  SafeSky Network Integration                            │
│  ┌─────┐  Enable SafeSky Network                        │
│  │ ON  │                                                │
│  └─────┘  Share drone positions + receive traffic.      │
│           No registration required.                     │
│  SafeSky API Key (optional)                             │
│  Enter your API key to keep receiving traffic after     │
│  the trial. Get your key at safesky-enterprise.com      │
Trial-Expiry Notification
│  ⚠  Your SafeSky 30-day trial has expired               │
│  You're still sharing your drone positions with the     │
│  SafeSky Network.                                       │
│  To continue receiving traffic data, subscribe at:      │
│  safesky-enterprise.com                                 │
│  [ Get API Key ]   [ Dismiss ]                          │
8. Security & Best Practices
  1. Protect the integration key. It is a shared secret embedded in your application, obfuscate it and never expose it in client-side source that is trivially readable. It can be rotated or revoked by SafeSky independently of your own contract key.
  2. One token, one trial, forever. Generate each customer's X-SS-Org-Id once, store it, and never change it (see Section 2 for the full token rules). SafeSky pins the first-seen token per trial and enforces one trial per organization to prevent trial farming (rotating tokens to reset the clock).
  3. Never use the integration key anonymously. Always pair it with X-SS-Org-Id; a missing header returns HTTP 400.
  4. Don't mix credentials. For a given request, use either the integration key or the customer's own key, never both.
  5. Trust the server, not the clock. Trial start, duration, and expiry are computed server-side, so device clocks and client tampering cannot extend a trial. Always rely on the response headers.
9. Integration Checklist
  • Obtain an integration key from SafeSky and embed it securely in your product.
  • Add an "Enable SafeSky Network" toggle plus an optional API key field to your settings.
  • Generate a unique, stable, opaque X-SS-Org-Id per customer (store once, reuse forever).
  • Send X-SS-Org-Id on every request while using the integration key.
  • Sign requests with the same HMAC scheme as a standard SafeSky key.
  • Read X-SS-Trial-Status / X-SS-Trial-Days-Remaining on responses to drive UI state.
  • On expiry, prompt for an API key and link to safesky-enterprise.com; keep POST sharing on.
  • When the customer enters their own key, switch authentication to that key.
10. Quick Reference
Item Value
Trial length 30 days, time-boxed (no usage quota)
Trial scope Per customer, keyed on X-SS-Org-Id
Auth (trial) Embedded integration key (HMAC) + X-SS-Org-Id
Auth (post-trial) Customer's own API key (HMAC)
Share positions (POST /v1/uav) Always available, free, before, during, and after trial
Receive traffic (GET /v1/uav) Full during trial → empty 200 after expiry
Integration key, no X-SS-Org-Id HTTP 400 Bad Request
Trial status headers X-SS-Trial-Status, X-SS-Trial-Days-Remaining
Get a key / subscribe https://www.safesky-enterprise.com
