Best Practices
Overview
This guide addresses the technical challenges of building responsive, scalable traffic layers for moving map applications: dynamic mapping interfaces where traffic must be rendered, updated, and managed in real-time as users interact with the map (panning, zooming, following UAV positions).
  • Performance optimisation for high-traffic-density areas
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
  • Resource optimisation: Non-blocking I/O prevents thread starvation
JavaScript Example:
  setInterval(async () => {
    try {
      updateTrafficLayer(traffic);
    } catch (error) {
  }, 3000);
    try {
      await postTelemetry(uavList);
    } catch (error) {
  }, 1000);
2. Traffic Retrieval Strategy
2.1 Viewport-Based Queries
2.2 Radius Queries
Trade-offs:
To avoid this, extend the queried viewport 5–15% beyond the visible map area. This technique, commonly referred to as overscan, allows the client to pre-fetch traffic that is about to enter the screen.
Implementation Example:
  return {
2.4 Polling Frequency
Network Optimisation:
Pre-connection health check pattern
For automated systems (mission control software, fleet managers), check platform status before initialising API connections or starting a flight:
const { status } = await fetch("https://status.safesky.app/api/v1/status")
  .then(r => r.json());
if (status === "disrupted") {
  throw new Error("SafeSky platform unavailable — aborting mission start");
More details about the API
This is especially relevant for systems that may attempt to start a flight without a human operator actively monitoring the connection state.
3.1 Live Traffic
Live traffic represents aircraft and UAVs that are actively broadcasting telemetry, such as ADS-B, FLARM, ADS-L, SafeSky, or UAV telemetry. These objects should be treated as moving tracked targets.
Typical characteristics:
  • Optional accuracy field (horizontal position accuracy in metres)
  "call_sign": "FlyingFrog",
  "accuracy": 10
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
3.3 Common Pitfalls
  • On user interaction:
GeoJSON Rendering Implementation
The following example demonstrates how to properly render advisory traffic from GeoJSON responses:
      const polygon = new Polygon({
        coordinates: [coordinates],
        stroke: 'rgb(255, 140, 0)',
        strokeWidth: 2
      const label = new Label({
        position: centroid,
        style: {
          padding: '4px',
          borderRadius: '4px'
      return [polygon, label];
      const circle = new Circle({
        radius: radius,
        strokeWidth: 2
      return circle;
  }).flat();
  return features;
  let x = 0, y = 0;
    x += coord[0];
    y += coord[1];
Rendering Best Practices:
  1. Coordinate Order: GeoJSON uses [longitude, latitude] order. Ensure your mapping library expects this format
  • Use different colours/styles to distinguish from live traffic
User Experience Guidelines:
    "id": "hx-137105",
    "latitude": 63.41303,
    "longitude": 10.11205,
    "accuracy": 1852,
    "call_sign": "HWX137105",
    "last_update": 1766068287,
    "altitude": 231,
    "id": "096E2863",
    "latitude": 59.17081,
    "longitude": 9.5268,
    "beacon_type": "HELICOPTER",
    "vertical_rate": 45,
    "call_sign": "ROTORWING 30",
    "transponder_type": "ADS-BI",
    "last_update": 1766068285,
    "altitude": 450,
    "altitude_accuracy": 10,
    "course": 315,
    "ground_speed": 54,
4. Publishing UAV Information
POST /v1/uav
4.2 Batch Publishing for Fleet Operations
Why Batch Publishing Matters:
For fleet operations, sending individual HTTP requests for each UAV creates unnecessary overhead. Consider a fleet of 10 UAVs publishing at 1Hz:
Individual 10 10 ~4KB 10× RTT
Batch 10 1 ~400B 1× RTT
Benefits: Single HTTP handshake, one round-trip instead of N, essential for swarm operations (20+ UAVs), and reduced risk of throttling
Implementation Strategy:
  1. Centralized Collection: Aggregate all UAV telemetry in a central data structure before publishing
  2. Atomic Updates: Publish the entire fleet state in one transaction
  3. Consistent Timestamps: Ensure all telemetry in a batch shares the same or very close last_update timestamp
  4. Error Handling: If the batch fails, retry the entire batch rather than individual UAVs
When to Use Batch Publishing:
  • Managing 2+ UAVs simultaneously
  • Swarm or coordinated multi-UAV operations
  • Fleet management dashboards
  • Cloud-based mission control systems
When Individual Publishing is Acceptable:
  • Single UAV operations only
  • Independent UAV systems with no central coordination
Best Practice: Even for 2 UAVs, use batch publishing. It simplifies your architecture and scales effortlessly as your fleet grows.
4.2.1 Example: Batch UAV Publish Payload
    "altitude": 120,
    "ground_speed": 12,
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
4.3 Pre-Flight Visibility
4.3.1 GROUNDED Status Broadcasting
One important aspect of UAV safety is pre-flight visibility: announcing your UAV's presence before it takes off.
Why Pre-Flight Broadcasting Matters:
In aviation, situational awareness begins before takeoff. Manned aircraft pilots (especially helicopter pilots operating at low altitudes) need advance notice of UAV operations in their vicinity. Broadcasting your UAV's position while still on the ground:
  • Allows nearby pilots to adjust their flight paths proactively
  • Prevents last-minute evasive maneuvers during critical flight phases (takeoff/landing)
  • Establishes your operational intent in shared airspace
  • Provides time for radio communication if needed
  • Enhances situational awareness during the vulnerable takeoff phase
GROUNDED Status Payload Example:
  "last_update": 1734537600
Key Payload Requirements:
  • status: Must be "GROUNDED" (not "INACTIVE")
  • altitude: Set to 0 or ground elevation
  • latitude/longitude: Exact takeoff location
  • last_update: Current timestamp
  • Continue publishing at 1Hz until takeoff
Timing Guidelines:
State Transition Workflow:
1. Power on UAV
2. Start publishing: status = "GROUNDED"
   (3-5 minutes before takeoff)
3. Conduct pre-flight checks
   (Continue publishing GROUNDED status)
4. UAV lifts off
5. Immediately switch: status = "AIRBORNE"
   (Within 1 second of takeoff)
Implementation Best Practices:
  1. Automate Based on Power-On: Start broadcasting GROUNDED status as soon as the UAV is powered and GPS lock is acquired
  2. Pre-Filed Flight Plans: If using mission planning software, automatically trigger GROUNDED broadcasting when flight plan is activated
  3. Visual Confirmation: In pilot interfaces, show a clear indicator that pre-flight broadcasting is active
  4. Delayed Takeoff Handling: If takeoff is delayed, continue broadcasting GROUNDED status. Do not stop or restart
  5. Multi-UAV Coordination: For fleet operations, stagger GROUNDED broadcasts if multiple UAVs are taking off from the same location
Critical Locations Requiring Pre-Flight Visibility:
  • Within 5 km of airports or helipads
  • Emergency service flight paths (air ambulance routes)
  • Near hospitals (frequent helicopter traffic)
  • Coastal areas (search and rescue operations)
  • Mountainous terrain (rescue helicopter activity)
  • Urban areas with general aviation traffic
Common Mistakes to Avoid:
  • Publishing only after takeoff (too late for nearby traffic)
  • Using status: "INACTIVE" instead of "GROUNDED"
  • Setting altitude to actual flight altitude while still on ground
  • Stopping broadcasts during pre-flight checks
  • Not updating position if UAV is moved before takeoff
4.4 Traffic Identity Fields — ICAO24 and Remote ID
When publishing UAV telemetry, two optional identity fields help SafeSky reconcile duplicate tracks and display your UAV as a single, unified traffic object across all sources on the network.
Without these fields, the same physical drone may appear as multiple independent icons if it is simultaneously detected by an RF receiver (ADS-B ground station, Remote ID scanner) and reported through the UAV API. Populating the relevant field eliminates that duplication.
4.4.1 icao24 — ADS-B Transponder Identity
If your UAV is equipped with an ADS-B transponder, a FLARM transmitter, or an ADS-L transmitter, populate the icao24 field with its ICAO 24-bit address. This allows SafeSky to match your UAV API track against the same aircraft detected by RF receivers (ADS-B ground stations, FLARM networks, ADS-L receivers) and suppress the duplicate.
  "icao24": "3C6444",
  "altitude": 120,
  "ground_speed": 12,
Format: 6 hexadecimal characters, uppercase (e.g. 3C6444).
Which address to use by avionics type:
Avionics on board icao24 value to populate
ADS-B transponder only The Mode-S address assigned to the transponder
FLARM only The FLARM device's 24-bit address
ADS-L only The ADS-L device's 24-bit address
ADS-B and FLARM / ADS-L The ADS-B transponder address — see note below
ADS-B + FLARM / ADS-L co-installation: when both are fitted, the only authoritative ICAO24 is the one assigned to the ADS-B transponder. The FLARM device must be configured to broadcast that same ICAO address using the ICAO address type, as defined in the FLARM user manual (address type 1 — ICAO). This ensures all RF sources agree on a single identity, which SafeSky can then match against the icao24 you publish here.
When to populate: only if the UAV is actively broadcasting on one of these technologies. Do not fabricate or reuse an address — ICAO 24-bit addresses are globally unique and assigned per device.
4.4.2 remote_id — Remote ID / CTA-2063-A Serial
If your UAV broadcasts a Remote ID (directly via Wi-Fi/BT per the CTA-2063-A standard, or through a compatible add-on device such as Dronetag), populate the remote_id field with the Basic-ID serial — the public identifier the drone broadcasts over the air.
  "remote_id": "1787F04BM24010010053",
  "altitude": 120,
  "ground_speed": 12,
Format: CTA-2063-A serial — typically 20 characters: 4-character manufacturer code + 1 length indicator + serial string (e.g. 1787F04BM24010010053).
When to populate: whenever the drone or its companion device (Dronetag, etc.) exposes the CTA-2063-A Basic-ID. Do not populate this field with a MAC address, an OGN-style string, or any self-assigned identifier — only registry-backed serials are meaningful as deduplication keys.
Effect: SafeSky can match the UAV API track against the same drone detected by a Remote ID scanner (e.g. the Avionix network) and suppress the duplicate.
4.4.3 Combining Both Fields
A UAV equipped with both an ADS-B transponder and a Remote ID module should populate both fields. SafeSky uses whichever match succeeds first and will never create more than one visible icon for the same physical aircraft.
  "icao24": "3C6444",
  "altitude": 120,
  "ground_speed": 12,
Key rules:
Condition Field to populate
UAV has an ADS-B transponder icao24 (ADS-B Mode-S address)
UAV has a FLARM transmitter icao24 (FLARM ICAO address)
UAV has an ADS-L transmitter icao24 (ADS-L ICAO address)
UAV has ADS-B and FLARM / ADS-L icao24 (ADS-B address; configure FLARM to use the same address as ICAO type)
UAV broadcasts Remote ID (CTA-2063-A) or uses Dronetag remote_id (Basic-ID serial)
UAV has both Both fields
Neither applies Omit both — the track is still shown, just not deduplicated
Important: these are deduplication hints, not primary identities. Your id field remains the primary key. icao24 and remote_id are only used to suppress duplicate icons when the same drone is seen from multiple sources simultaneously.
5. Smooth Motion Rendering
In moving map applications, the quality of traffic animation directly impacts user confidence and situational awareness. Jerky or teleporting aircraft icons create confusion and undermine trust in the system's accuracy. Professional aviation displays maintain smooth, predictable motion even with infrequent updates.
This section addresses the challenge of rendering fluid 25fps animation when traffic data arrives only every 3 seconds. The solution is client-side position extrapolation (dead reckoning), a technique widely used in aviation navigation systems and air traffic control displays.
5.1 Client-Side Position Extrapolation
Algorithm:
  return {
Animation Approach: Use requestAnimationFrame to call extrapolatePosition for each traffic marker at 25fps, creating smooth motion between 3-second API updates.
Performance Optimisation for Zoom Levels: At higher zoom levels (zoomed out, showing large geographical areas), animation frame rate can be progressively reduced:
  • Close zoom (city-level view): 25fps for smooth, professional motion
  • Medium zoom (regional view): 10-15fps provides adequate fluidity
  • Far zoom (country/continent view): 1fps (matching API update rate) is sufficient
At distant zoom levels, aircraft appear as small icons with minimal apparent motion, making high frame rates unnecessary. This optimisation significantly reduces CPU usage when displaying large numbers of aircraft.
Rendering Impact:
  • Transforms discrete position updates into fluid animation
  • Scales efficiently across different zoom levels
Limitation: Extrapolation assumes constant velocity and heading. Manoeuvring aircraft may show brief position discrepancies until the next update.
6. Map Layer Management
In complex moving map applications displaying multiple traffic types, proper layer organisation is critical for both visual clarity and user interaction. Poor layer management leads to advisory overlays blocking live traffic clicks, labels obscuring icons, or uncertainty indicators rendering above precise position markers.
This section provides a proven layer architecture that ensures:
  • Correct visual hierarchy (most important information on top)
  • Proper interaction handling (clicks reach the intended targets)
  • Clean separation between different traffic types
  • Consistent behaviour across different mapping libraries
The layer stack design follows aviation display standards where precision information (live traffic) always takes visual precedence over advisory information (operational areas).
6.1 Layer Z-Index Organisation
Key Principles:
7. Traffic Aging and Expiry
Displaying stale traffic data as if it were current is one of the most dangerous mistakes in aviation situational awareness systems. An aircraft shown at a 2-minute-old position could be miles away from that location, leading to false assumptions about separation and safety.
This section establishes data freshness policies that balance practical update rates with safety requirements. The approach mirrors aviation standards: as data ages, visual confidence indicators degrade progressively until the data is removed entirely.
Key principle: Never show old data as if it were current. Users must always know when position information is becoming uncertain.
7.1 Data Freshness Management
Data freshness is fundamental to aviation safety. Displaying outdated position information as if it were current creates false situational awareness and can lead to dangerous assumptions about separation and traffic patterns.
Different traffic sources require different expiry policies based on their operational characteristics:
  • Speed differential: Fast jets (400+ knots) cover 200+ metres per second; slower UAVs cover 10-20 metres per second
  • Update frequency: Live transponders update every 1-3 seconds; advisory areas update every 30-60 seconds
  • Precision expectations: Point positions require strict freshness; area declarations remain valid longer
  • Consequence of staleness: Manned aviation position errors significantly degrade situational awareness; advisory area drift has less impact
The policies below establish when data transitions from current → stale → expired, with visual feedback at each stage.
7.1.1 Advisory UAV Traffic (Operational Areas)
Advisory traffic represents declared operational areas rather than live tracked positions. These are typically polygons or circles indicating where UAV activity is planned or ongoing, often filed in advance through flight planning systems.
Characteristics:
  • Slower aircraft (UAVs typically <100 knots)
  • Area-based (not point-based) awareness
  • Operational intent rather than tactical position
  • Lower positional precision requirements
Freshness Policy:
Age State Action
0-120s Current Display at full opacity with normal styling
>120s Expired Remove from display
Rationale: Advisory areas represent planned operations. After 2 minutes without updates, remove from display to prevent stale operational areas from cluttering the map.
Implementation Note: If an advisory area has an explicit end time in its metadata, respect that time regardless of last update age.
7.1.2 Live Traffic (ADS-B, FLARM, ADS-L, SafeSky)
Live traffic from transponders and telemetry systems demands strict freshness policies due to high speeds and rapid position changes. This category includes:
  • ADS-B: Automatic Dependent Surveillance-Broadcast (commercial aviation, general aviation)
  • FLARM: Traffic awareness system (gliders, light aircraft)
  • ADS-L: Low-power ADS-B variant
  • SafeSky: Smartphone-based telemetry from manned pilots
Speed Context:
  • Commercial jets: 400-550 knots (200-280 metres/second)
  • General aviation: 80-200 knots (40-100 metres/second)
  • Helicopters: 80-150 knots (40-75 metres/second)
  • UAVs with live telemetry: 10-80 knots (5-40 metres/second)
At these speeds, even 30 seconds of staleness can represent 1-8 kilometres of position error for fast aircraft.
Freshness Policy:
Age State Visual Feedback User Interpretation
0-30s Current Full opacity, normal icon, solid colour "This position is reliable for tactical decisions"
30-45s Stale 70% opacity + expanding uncertainty circle "Position is approximate; exercise caution"
>45s Expired Remove from display entirely N/A—do not show
Uncertainty Circle Implementation:
For the 30-45s stale period, display an expanding semi-transparent circle that visualises position drift:
function getTimeBasedUncertaintyRadius(lastUpdate, currentTime, groundSpeed) {
  if (ageSeconds < 30) return 0; // No circle for fresh data
  // Calculate maximum distance aircraft could have travelled
  return maxDistanceMeters;
Visual Design: Semi-transparent circle (20-30% opacity) that grows linearly as data ages from 30 to 45 seconds.
Critical Safety Rule: Never display traffic data older than 45 seconds. Showing a "frozen" aircraft icon at a stale position creates false confidence in separation that may no longer exist.
7.1.3 Accuracy-Based Uncertainty
In addition to time-based staleness (covered in Section 7.1.2 above), position uncertainty also arises from measurement accuracy limitations. The accuracy field indicates inherent position uncertainty in the reported coordinates.
Sources of Accuracy Degradation:
  • Mode-S multilateration: Position triangulated from ground stations rather than GPS
  • GPS degradation: Poor satellite geometry, signal interference, multipath
  • Data source constraints: Technology precision limits
Implementation:
function getAccuracyCircleRadius(aircraft) {
  // accuracy field is in metres
  return aircraft.accuracy > 0 ? aircraft.accuracy : 0;
function shouldDisplayAccuracyCircle(aircraft) {
  return aircraft.accuracy && aircraft.accuracy > 50; // Show for >50m uncertainty
Visual Design: Display a semi-transparent uncertainty circle if accuracy > 50 metres.
Combined Uncertainty Visualisation:
When both staleness and accuracy contribute to uncertainty, display the larger of the two radii:
function getCombinedUncertaintyRadius(aircraft, currentTime) {
  const timeBasedRadius = getTimeBasedUncertaintyRadius(
    aircraft.last_update,
    currentTime,
  const accuracyRadius = aircraft.accuracy || 0;
  return Math.max(timeBasedRadius, accuracyRadius);
Example: Aircraft with accuracy: 500 metres and data age of 35 seconds (time-based uncertainty ~150m at 100 knots) displays a 500-metre uncertainty circle.
  • Always show uncertainty circles: Hiding uncertainty creates false confidence
  • Distinct styling: Use different colours/opacity than advisory areas
  • Tooltip information: Display "Position accuracy: ±500m" or "Data age: 35s" on hover
  • Icon treatment: Reduce icon opacity or add pulsing for high-uncertainty traffic
  • Never hide indicators: Aviation safety requires honest uncertainty representation
Rationale: Pilots and operators must understand when position data is approximate versus precise.
Visual Example:
The image below demonstrates proper uncertainty visualisation with expanding circles for aged data:
8. Visual Design Guidelines
Visual design in aviation safety systems is not merely aesthetic. It directly impacts a pilot's ability to quickly identify threats, assess separation, and make time-critical decisions. Icons must be instantly recognisable at a glance, even in high-workload scenarios or poor lighting conditions.
This section provides design standards based on:
  • International aviation iconography conventions
  • Human factors research in cockpit displays
  • Accessibility requirements for diverse user populations
  • Real-world feedback from pilots and UAV operators
The goal is to create a visual language that is intuitive, unambiguous, and consistent with expectations from professional aviation systems.
Traffic Icon Visual States: For detailed guidance on progressive visual feedback (opacity changes, uncertainty circles, and expiry timing), refer to Section 7.1 Data Freshness Management, which establishes the authoritative policy for live and advisory traffic rendering.
8.1 Traffic Categorization
Accessibility Note: Ensure icons are distinguishable by shape, not just colour, for colour-blind users.
9. Icon Assets
SafeSky provides optimised icon sets for rapid integration.
Download: aircraft_icons.zip
Beacon Type to Icon Mapping:
UNKNOWN dot.svg —
STATIC_OBJECT dot.svg —
GLIDER glider.svg —
PARA_GLIDER para_glider.svg —
HAND_GLIDER hand_glider.svg —
PARA_MOTOR para_motor.svg —
PARACHUTE parachute.svg —
MOTORPLANE aircraft.svg —
JET heavy_aircraft.svg —
AIRSHIP airship.svg —
BALLOON ballon.svg —
UAV uav.svg —
PAV pav.svg —
MILITARY military.svg —
10. Configuration Reference
10.1 Timing Parameters
Parameter Value Rationale
Uncertainty visualisation 30 seconds after update Reflects realistic position drift
11. Reference Implementation
  • Progressive data aging with uncertainty visualisation
Use the browser developer tools to observe network traffic patterns, polling behaviour, and rendering optimisations in a production environment.
