Best Practices
Overview
This guide addresses the technical challenges of building responsive, scalable traffic layers for moving map applications—: dynamic mapping interfaces where traffic must be rendered, updated, and managed in real-time as users interact with the map (panning, zooming, following UAV positions).
  • Performance optimizationoptimisation for high-traffic-density areas
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
  • Resource optimization:optimisation: Non-blocking I/O prevents thread starvation
JavaScript Example:
  setInterval(async () => {
    try {
      updateTrafficLayer(traffic);
    } catch (error) {
  }, 3000);
    try {
      await postTelemetry(uavList);
    } catch (error) {
  }, 1000);
2. Traffic Retrieval Strategy
2.1 Viewport-Based Queries
2.2 Radius Queries
Trade-offs:
To avoid this, extend the queried viewport 5–15% beyond the visible map area. This technique—technique, commonly referred to as overscan, allows the client to pre-fetch traffic that is about to enter the screen.
Implementation Example:
  return {
2.4 Polling Frequency
Network Optimization:Optimisation:
3.1 Live Traffic
Live traffic represents aircraft and UAVs that are actively broadcasting telemetry, such as ADS-B, FLARM, ADS-L, SafeSky, or UAV telemetry. These objects should be treated as moving tracked targets.
Typical characteristics:
  • Optional accuracy information
  "call_sign": "FlyingFrog",
  "accuracy": 10
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
3.3 Common Pitfalls
  • On user interaction:
  • Apply
different
GeoJSON ageingRendering thresholds:Implementation
    The
    Livefollowing example demonstrates how to properly render advisory traffic expiresfrom quicklyGeoJSON to avoid stale precision. Advisory traffic persists longer but updates infrequently.
    Display Recommendations
    Displaying Live Traffic
    Live traffic should be rendered as precise point symbols with real-time updates:
    Visual Styling:
      Icon: Aircraft/UAV symbol oriented by course heading Position: Exact lat/lng coordinates Animation: Smooth extrapolation between updates Label: Show call_sign, altitude, and ground_speed Color: Solid, distinct color by beacon_type
      Implementation:
        Use standard aircraft icons (see Section 10) Apply position extrapolation (see Section 6) Update icon rotation based on course Display motion vector or heading indicator
        Displaying Advisory Traffic
        Advisory traffic should be rendered as area indicators rather than precise points.
        Visual Styling:
          Fill: Semi-transparent orange/amber (20-30% opacity) Stroke: Solid distinct color (e.g., rgb(255, 140, 0)) Label: Show call_sign and max_altitude Z-Index: Below live traffic No heading indicator: Advisory areas are static zones
          responses:
                const polygon = new Polygon({
                  coordinates: [coordinates],
                  stroke: 'rgb(255, 140, 0)',
                  strokeWidth: 2
                const label = new Label({
                  position: centroid,
                  style: {
                    padding: '4px',
                    borderRadius: '4px'
                return [polygon, label];
                const circle = new Circle({
                  radius: radius,
                  strokeWidth: 2
                return circle;
            }).flat();
            return features;
            let x = 0, y = 0;
              x += coord[0];
              y += coord[1];
          Rendering Best Practices:
          1. Coordinate Order: GeoJSON uses [longitude, latitude] order—ensureorder. Ensure your mapping library expects this format
          • Use different colors/colours/styles to distinguish from live traffic
          User Experience Guidelines:
              "id": "hx-137105",
              "latitude": 63.41303,
              "longitude": 10.11205,
              "accuracy": 1852,
              "call_sign": "HWX137105",
              "last_update": 1766068287,
              "altitude": 231,
              "id": "096E2863",
              "latitude": 59.17081,
              "longitude": 9.5268,
              "beacon_type": "HELICOPTER",
              "vertical_rate": 45,
              "call_sign": "ROTORWING 30",
              "transponder_type": "ADS-BI",
              "last_update": 1766068285,
              "altitude": 450,
              "altitude_accuracy": 10,
              "course": 315,
              "ground_speed": 54,
          4. Publishing UAV Information
          POST /v1/uav
          4.2 Batch Publishing for Fleet Operations
          PerformanceWhy Comparison:Batch Publishing Matters:
          For fleet operations, sending individual HTTP requests for each UAV creates unnecessary overhead. Consider a fleet of 10 UAVs publishing at 1Hz:
          Individual 10 10 ~4KB 10× RTT
          Batch 10 1 ~400B 1× RTT
          Key Benefits:
            Reduced overhead: Single HTTP handshakehandshake, vs. multiple connections Lower latency: Oneone round-trip instead of NN, round-trips Improved scalability: Essentialessential for swarm operations (20+ UAVs), and reduced risk of throttling
            Implementation Strategy:
              Centralized Collection: Aggregate all UAV telemetry in a central data structure before publishing Atomic Updates: Publish the entire fleet state in one transaction Consistent Timestamps: Ensure all telemetry in a batch shares the same or very close last_update timestamp Error Handling: If the batch fails, retry the entire batch rather than individual UAVs
              When to Use Batch Publishing:
                Managing 2+ UAVs simultaneously Swarm or coordinated multi-UAV operations Fleet management dashboards Cloud-based mission control systems
                When Individual Publishing is Acceptable:
                  Single UAV operations only Independent UAV systems with no central coordination
                  Best Practice: AggregateEven telemetryfor in2 UAVs, use batch publishing. It simplifies your application looparchitecture and publishscales theeffortlessly entireas your fleet state atomically.grows.
                  4.2.1 Example: Batch UAV Publish Payload
                      "altitude": 120,
                      "ground_speed": 12,
                      "latitude": 48.87012,
                      "longitude": 2.64188,
                      "altitude": 115,
                      "course": 210,
                      "ground_speed": 10,
                  5.
                  4.3 Pre-Flight Visibility
                  4.3.1 GROUNDED Status Broadcasting
                  PublishOne important aspect of UAV positionsafety with status: "GROUNDED"is 3-5pre-flight minutesvisibility: announcing your UAV's presence before it takes off.
                  Why Pre-Flight Broadcasting Matters:
                  In aviation, situational awareness begins before takeoff. Manned aircraft pilots (especially helicopter pilots operating at low altitudes) need advance notice of UAV operations in their vicinity. Broadcasting your UAV's position while still on the ground:
                    Allows nearby pilots to adjust their flight paths proactively Prevents last-minute evasive maneuvers during critical flight phases (takeoff/landing) Establishes your operational intent in shared airspace Provides time for radio communication if needed Reduces collision risk during the vulnerable takeoff phase
                    GROUNDED Status Payload Example:.
                      "last_update": 1734537600
                    OperationalKey Rationale:Payload Requirements:
                    • Providesstatus: advancedMust notificationbe "GROUNDED" (not "INACTIVE")
                    altitude: Set to nearby0 crewedor aircraftground and helicopterselevation Establisheslatitude/longitude: situationalExact awarenesstakeoff before airspace usagelocation Alignslast_update: withCurrent aviation practice of pre-flight intent signalingtimestamp ParticularlyContinue importantpublishing nearat helipads,1Hz airports,until or low-altitude flight zonestakeoff
                    Timing Guidelines:
                    Scenario Recommended Pre-Flight Time Urban areas, near airports 5 minutes before takeoff Rural areas, low traffic density 3 minutes before takeoff Emergency operations As soon as UAV is powered on Planned missions Align with flight plan filing
                    State Transition: Transition Workflow:
                    1. Power on UAV
                    2. Start publishing: status = "GROUNDED"
                       (3-5 minutes before takeoff)
                    3. Conduct pre-flight checks
                       (Continue publishing GROUNDED status)
                    4. UAV lifts off
                    5. Immediately switch: status = "AIRBORNE"
                       (Within 1 second of takeoff)
                    Implementation Best Practices:
                      Automate Based on Power-On: Start broadcasting GROUNDED status as soon as the UAV is powered and GPS lock is acquired Pre-Filed Flight Plans: If using mission planning software, automatically trigger GROUNDED broadcasting when flight plan is activated Visual Confirmation: In pilot interfaces, show a clear indicator that pre-flight broadcasting is active Delayed Takeoff Handling: If takeoff is delayed, continue broadcasting GROUNDED status. Do not stop or restart Multi-UAV Coordination: For fleet operations, stagger GROUNDED broadcasts if multiple UAVs are taking off from the same location
                      Critical Locations Requiring Pre-Flight Visibility:
                        Within 5 km of airports or helipads Emergency service flight paths (air ambulance routes) Near hospitals (frequent helicopter traffic) Coastal areas (search and rescue operations) Mountainous terrain (rescue helicopter activity) Urban areas with general aviation traffic
                        Common Mistakes to Avoid:
                          Publishing only after takeoff (too late for nearby traffic) Using status: "AIRBORNE"INACTIVE" immediatelyinstead uponof takeoff"GROUNDED" Setting altitude to reflect actual flight status.altitude
                          Implementationwhile Note: For mission planning applications, this can be automated basedstill on ground
                          Stopping broadcasts during pre-filed flight planschecks orNot launchupdating schedules.position if UAV is moved before takeoff
                          6.5. Smooth Motion Rendering
                          In moving map applications, the quality of traffic animation directly impacts user confidence and situational awareness. Jerky or teleporting aircraft icons create confusion and undermine trust in the system's accuracy. Professional aviation displays maintain smooth, predictable motion even with infrequent updates.
                          This section addresses the challenge of rendering fluid 25fps animation when traffic data arrives only every 3 seconds. The solution is client-side position extrapolation (dead reckoning), a technique widely used in aviation navigation systems and air traffic control displays.
                          5.1 Client-Side Position Extrapolation
                          Algorithm:
                            return {
                          Animation Approach: Use requestAnimationFrame to call extrapolatePosition for each traffic marker at 60fps,25fps, creating smooth motion between 3-second API updates.
                          Performance Optimisation for Zoom Levels: At higher zoom levels (zoomed out, showing large geographical areas), animation frame rate can be progressively reduced:
                            Close zoom (city-level view): 25fps for smooth, professional motion Medium zoom (regional view): 10-15fps provides adequate fluidity Far zoom (country/continent view): 1fps (matching API update rate) is sufficient
                            At distant zoom levels, aircraft appear as small icons with minimal apparent motion, making high frame rates unnecessary. This optimisation significantly reduces CPU usage when displaying large numbers of aircraft.
                            Rendering Impact:
                            • Transforms discrete position updates into fluid 60fps animation
                            • Scales efficiently across different zoom levels
                            Limitation: Extrapolation assumes constant velocity and heading. ManeuveringManoeuvring aircraft may show brief position discrepancies until the next update.
                            7.6. Map Layer Management
                            In complex moving map applications displaying multiple traffic types, proper layer organisation is critical for both visual clarity and user interaction. Poor layer management leads to advisory overlays blocking live traffic clicks, labels obscuring icons, or uncertainty indicators rendering above precise position markers.
                            This section provides a proven layer architecture that ensures:
                              Correct visual hierarchy (most important information on top) Proper interaction handling (clicks reach the intended targets) Clean separation between different traffic types Consistent behaviour across different mapping libraries
                              The layer stack design follows aviation display standards where precision information (live traffic) always takes visual precedence over advisory information (operational areas).
                              6.1 Layer Z-Index OrganizationOrganisation
                              Key Principles:
                              8.7. Traffic Aging and Expiry
                              Displaying stale traffic data as if it were current is one of the most dangerous mistakes in aviation situational awareness systems. An aircraft shown at a 2-minute-old position could be miles away from that location, leading to false assumptions about separation and safety.
                              This section establishes data freshness policies that balance practical update rates with safety requirements. The approach mirrors aviation standards: as data ages, visual confidence indicators degrade progressively until the data is removed entirely.
                              Key principle: Never show old data as if it were current. Users must always know when position information is becoming uncertain.
                              7.1 Data Freshness Management
                              Data freshness is fundamental to aviation safety. Displaying outdated position information as if it were current creates false situational awareness and can lead to dangerous assumptions about separation, traffic patterns, and collision avoidance.
                              Different traffic sources haverequire different validityexpiry windowspolicies based on their updateoperational characteristics.characteristics:
                              Advisory UAV Traffic:
                              • Validity:Speed differential: UpFast tojets 2(400+ minutesknots) aftercover last200+ updatemetres per second; slower UAVs cover 10-20 metres per second
                              • Rationale:Update frequency: LowerLive speedtransponders andupdate predictableevery flight1-3 patternsseconds; advisory areas update every 30-60 seconds
                              • Display:Precision expectations: ApplyPoint visualpositions indicatorsrequire forstrict agedfreshness; dataarea (reduceddeclarations opacity,remain uncertaintyvalid ring)longer
                              Consequence of staleness: Manned aviation position errors create immediate collision risk; advisory area drift is lower risk
                              The policies below establish when data transitions from current → stale → expired, with visual feedback at each stage.
                              Real-Time7.1.1 AirAdvisory UAV Traffic (ADS-B,Operational FLARM,Areas)
                              ADS-L):
                              Advisory traffic represents declared operational areas rather than live tracked positions. These are typically polygons or circles indicating where UAV activity is planned or ongoing, often filed in advance through flight planning systems.
                              Characteristics:
                                Slower aircraft (UAVs typically <100 knots) Area-based (not point-based) awareness Operational intent rather than tactical position Lower positional precision requirements
                                Freshness Policy:
                                Age State VisualizationAction
                                0-90s Current Display at full opacity with normal styling 90s-120s Aging Reduce opacity to 70%; add subtle visual indicator >120s Expired Remove from display
                                Rationale: Advisory areas change slowly as they represent planned operations. A 2-minute validity window accommodates typical update intervals whilst preventing long-stale operational areas from cluttering the display.
                                Implementation Note: If an advisory area has an explicit end time in its metadata, respect that time regardless of last update age.
                                7.1.2 Live Traffic (ADS-B, FLARM, ADS-L, SafeSky)
                                Live traffic from transponders and telemetry systems demands strict freshness policies due to high speeds and rapid position changes. This category includes:
                                  ADS-B: Automatic Dependent Surveillance-Broadcast (commercial aviation, general aviation) FLARM: Collision avoidance system (gliders, light aircraft) ADS-L: Low-power ADS-B variant SafeSky: Smartphone-based telemetry from manned pilots
                                  Speed Context:
                                    Commercial jets: 400-550 knots (200-280 metres/second) General aviation: 80-200 knots (40-100 metres/second) Helicopters: 80-150 knots (40-75 metres/second) UAVs with live telemetry: 10-80 knots (5-40 metres/second)
                                    At these speeds, even 30 seconds of staleness can represent 1-8 kilometres of position error for fast aircraft.
                                    Freshness Policy:
                                    Age State Visual Feedback User Interpretation 0-30s Current Full opacity, normal iconicon, solid colour "This position is reliable for tactical decisions" 30-45s Stale Reduced70% opacity + expanding uncertainty circle "Position is approximate; exercise caution" >45s Expired Remove from display entirely N/A—do not show
                                    Critical Safety Rule:
                                    Never display traffic data older than 45 seconds. Showing a "frozen" aircraft icon at a stale position creates false confidence in separation that may no longer exist. An aircraft displayed 1 minute ago could be 10+ kilometres from that position.
                                    Rationale for 45-Second Cutoff:
                                      Transponder update rates: 1-3 seconds typical Network/processing delays: 2-5 seconds typical Grace period for temporary signal loss: 30-40 seconds Safety margin: After 45s total, position uncertainty exceeds acceptable limits
                                      Implementation Guidance:
                                      const MAX_AGE_SECONDS = 45;
                                      const STALE_THRESHOLD_SECONDS = 30;
                                      function shouldDisplayTraffic(aircraft, currentTime) {
                                        const ageSeconds = (currentTime - aircraft.last_update) / 1000;
                                        return ageSeconds <= MAX_AGE_SECONDS;
                                      function getTrafficOpacity(aircraft, currentTime) {
                                        if (ageSeconds < STALE_THRESHOLD_SECONDS) return 1.0;
                                        if (ageSeconds < MAX_AGE_SECONDS) return 0.7;
                                        return 0; // Should not be displayed
                                      7.1.3 Uncertainty Visualization:Visualisation
                                      Implementation Approach:
                                        // Assume maximum maneuveringmanoeuvring potential
                                      9.8. Visual Design Guidelines
                                      Visual design in aviation safety systems is not merely aesthetic. It directly impacts a pilot's ability to quickly identify threats, assess separation, and make time-critical decisions. Icons must be instantly recognisable at a glance, even in high-workload scenarios or poor lighting conditions.
                                      This section provides design standards based on:
                                        International aviation iconography conventions Human factors research in cockpit displays Accessibility requirements for diverse user populations Real-world feedback from pilots and UAV operators
                                        The goal is to create a visual language that is intuitive, unambiguous, and consistent with expectations from professional aviation systems.
                                        8.1 Traffic Icon States
                                        Solid icon
                                        Full colorcolour
                                        70% opacity
                                        Subtle pulse
                                        8.2 Traffic Categorization
                                        Accessibility Note: Ensure icons are distinguishable by shape, not just color,colour, for colorblindcolour-blind users.
                                        10.9. Icon Assets
                                        SafeSky provides optimizedoptimised icon sets for rapid integration.
                                        Download: aircraft_icons.zip
                                        Beacon Type to Icon Mapping:
                                        UNKNOWN dot.svg —
                                        STATIC_OBJECT dot.svg —
                                        GLIDER glider.svg —
                                        PARA_GLIDER para_glider.svg —
                                        HAND_GLIDER hand_glider.svg —
                                        PARA_MOTOR para_motor.svg —
                                        PARACHUTE parachute.svg —
                                        MOTORPLANE aircraft.svg —
                                        JET heavy_aircraft.svg —
                                        AIRSHIP airship.svg —
                                        BALLOON ballon.svg —
                                        UAV uav.svg —
                                        PAV pav.svg —
                                        MILITARY military.svg —
                                        11.10. Configuration Reference
                                        10.1 Timing Parameters
                                        Parameter Value Rationale
                                        Uncertainty visualizationvisualisation 30 seconds after update Reflects realistic position drift
                                        12.11. Reference Implementation
                                        • Progressive data aging with uncertainty visualizationvisualisation
                                        Use the browser developer tools to observe network traffic patterns, polling behavior,behaviour, and rendering optimizationsoptimisations in a production environment.
