Best Practices
Overview
This guide addresses the technical challenges of building responsive, scalable traffic layers for moving map applications—dynamic mapping interfaces where traffic must be rendered, updated, and managed in real-time as users interact with the map (panning, zooming, following UAV positions).
  • Performance optimization for high-traffic-density areas
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
JavaScript Example:
  setInterval(async () => {
    try {
      updateTrafficLayer(traffic);
    } catch (error) {
  }, 3000);
    try {
      await postTelemetry(uavList);
    } catch (error) {
  }, 1000);
2. Traffic Retrieval Strategy
2.1 Viewport-Based Queries
2.2 Radius Queries
Trade-offs:
To avoid this, extend the queried viewport 5–15% beyond the visible map area. This technique—commonly referred to as overscan allows the client to pre-fetch traffic that is about to enter the screen.
Implementation Example:
  return {
2.4 Polling Frequency
Network Optimization:
3.1 Live Traffic
Live traffic represents aircraft and UAVs that are actively broadcasting telemetry, such as ADS-B, FLARM, ADS-L, or UAV telemetry. These objects should be treated as moving tracked targets.
Typical characteristics:
  • Optional accuracy information
  "call_sign": "FlyingFrog",
  "accuracy": 10
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
3.3 Common Pitfalls
  • On user interaction:
  • Apply different ageing thresholds:
    • Live traffic expires quickly to avoid stale precision.
    • Advisory traffic persists longer but updates infrequently.
Display Recommendations
Displaying Live Traffic
Visual Styling:
Implementation:
  • Use standard aircraft icons (see Section 9)10)
Displaying Advisory Traffic
Visual Styling:
  • Z-Index: Below live traffic
      const polygon = new Polygon({
        coordinates: [coordinates],
        stroke: 'rgb(255, 140, 0)',
        strokeWidth: 2
      const label = new Label({
        position: centroid,
        style: {
          padding: '4px',
          borderRadius: '4px'
      return [polygon, label];
      const circle = new Circle({
        radius: radius,
        strokeWidth: 2
      return circle;
  }).flat();
  return features;
  let x = 0, y = 0;
    x += coord[0];
    y += coord[1];
Rendering Best Practices:
User Experience Guidelines:
    "id": "hx-137105",
    "latitude": 63.41303,
    "longitude": 10.11205,
    "accuracy": 1852,
    "call_sign": "HWX137105",
    "last_update": 1766068287,
    "altitude": 231,
    "id": "096E2863",
    "latitude": 59.17081,
    "longitude": 9.5268,
    "beacon_type": "HELICOPTER",
    "vertical_rate": 45,
    "call_sign": "ROTORWING 30",
    "transponder_type": "ADS-BI",
    "last_update": 1766068285,
    "altitude": 450,
    "altitude_accuracy": 10,
    "course": 315,
    "ground_speed": 54,
4. Publishing UAV Information
POST /v1/uav
Performance Comparison:
Individual 10 10 ~4KB 10× RTT
Batch 10 1 ~400B 1× RTT
Key Benefits:
    "altitude": 120,
    "ground_speed": 12,
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
5. Pre-Flight Visibility
GROUNDED Status Broadcasting
  "last_update": 1734537600
Operational Rationale:
6. Smooth Motion Rendering
Algorithm:
  return {
Animation Approach: Use requestAnimationFrame to call extrapolatePosition for each traffic marker at 60fps, creating smooth motion between 3-second API updates.
Rendering Impact:
7. Map Layer Management
Layer Z-Index Organization
Key Principles:
8. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic:
Age State Visualization
Uncertainty Visualization:
Implementation Approach:
9. Visual Design Guidelines
Traffic Icon States
Solid icon
Full color
70% opacity
Subtle pulse
Traffic Categorization
10. Icon Assets
Download: aircraft_icons.zip
Beacon Type to Icon Mapping:
UNKNOWN dot.svg —
STATIC_OBJECT dot.svg —
GLIDER glider.svg —
PARA_GLIDER para_glider.svg —
HAND_GLIDER hand_glider.svg —
PARA_MOTOR para_motor.svg —
PARACHUTE parachute.svg —
MOTORPLANE aircraft.svg —
JET heavy_aircraft.svg —
AIRSHIP airship.svg —
BALLOON ballon.svg —
UAV uav.svg —
PAV pav.svg —
MILITARY military.svg —
11. Configuration Reference
Timing Parameters
Parameter Value Rationale
12. Reference Implementation
