Best Practices
Overview
This guide addresses the technical challenges of building responsive, scalable traffic layers for moving map applications—dynamic mapping interfaces where traffic must be rendered, updated, and managed in real-time as users interact with the map (panning, zooming, following UAV positions).
    Efficient viewport-based traffic queries that meetadapt operationalto aviationmap standards.interactions Smooth traffic rendering with position extrapolation between updates Layer management and z-index handling for mixed traffic types Performance optimization for high-traffic-density areas Coordinate system handling and map projection compatibility
    Key Design Goals
    1. Integration Architecture
    Dual-Thread Pattern
    Architectural Benefits:
    JavaScript Example:
      setInterval(async () => {
        try {
          updateTrafficLayer(traffic);
        } catch (error) {
      }, 3000);
        try {
          await postTelemetry(uavList);
        } catch (error) {
      }, 1000);
    2. Traffic Retrieval Strategy
    Viewport-Based Queries
    Radius Queries
    Trade-offs:
    Viewport Padding (Overscan)
    To avoid this, extend the queried viewport 5–15% beyond the visible map area. This technique—commonly referred to as overscan allows the client to pre-fetch traffic that is about to enter the screen.
    Implementation Example:
      return {
    Polling Frequency
    Network Optimization:
    Debounce rapid viewport changes (wait 300-500ms after user stops moving map) Only query when viewport changes significantly (>20% of current bounds)
    3.1 Live Traffic
    Live traffic represents aircraft and UAVs that are actively broadcasting telemetry, such as ADS-B, FLARM, ADS-L, or UAV telemetry. These objects should be treated as moving tracked targets.
    Typical characteristics:
    • Optional accuracy information
      "call_sign": "FlyingFrog",
      "accuracy": 10
            "id": "Advisory123",
            "call_sign": "UAV_Alpha",
            "last_update": 1738142598,
            "max_altitude": 150,
            "remarks": "Surveying area"
            "coordinates": [
                [4.39201, 50.69378],
                [4.39300, 50.69400],
                [4.39400, 50.69500],
                [4.39201, 50.69378]
    3.3 Common Pitfalls
    • On user interaction:
    • Apply different ageing thresholds:
      • Live traffic expires quickly to avoid stale precision.
      • Advisory traffic persists longer but updates infrequently.
    Display Recommendations
    Displaying Live Traffic
    Visual Styling:
    Implementation:
    Displaying Advisory Traffic
    Visual Styling:
    • Z-Index: Below live traffic
          const polygon = new Polygon({
            coordinates: [coordinates],
            stroke: 'rgb(255, 140, 0)',
            strokeWidth: 2
          const label = new Label({
            position: centroid,
            style: {
              padding: '4px',
              borderRadius: '4px'
          return [polygon, label];
          const circle = new Circle({
            radius: radius,
            strokeWidth: 2
          return circle;
      }).flat();
      return features;
      let x = 0, y = 0;
        x += coord[0];
        y += coord[1];
    Rendering Best Practices:
    User Experience Guidelines:
        "id": "hx-137105",
        "latitude": 63.41303,
        "longitude": 10.11205,
        "accuracy": 1852,
        "call_sign": "HWX137105",
        "last_update": 1766068287,
        "altitude": 231,
        "id": "096E2863",
        "latitude": 59.17081,
        "longitude": 9.5268,
        "beacon_type": "HELICOPTER",
        "vertical_rate": 45,
        "call_sign": "ROTORWING 30",
        "transponder_type": "ADS-BI",
        "last_update": 1766068285,
        "altitude": 450,
        "altitude_accuracy": 10,
        "course": 315,
        "ground_speed": 54,
    4. Publishing UAV Information
    POST /v1/uav
    Performance Comparison:
    Individual 10 10 ~4KB 10× RTT
    Batch 10 1 ~400B 1× RTT
    Key Benefits:
        "altitude": 120,
        "ground_speed": 12,
        "latitude": 48.87012,
        "longitude": 2.64188,
        "altitude": 115,
        "course": 210,
        "ground_speed": 10,
    5. Pre-Flight Visibility
    GROUNDED Status Broadcasting
      "last_update": 1734537600
    Operational Rationale:
    6. Smooth Motion Rendering
    Algorithm:
      const distanceMeters = aircraft.ground_speed * 0.514444 * elapsedSeconds; // knots to m/s
      return {
    Animation Approach: Use requestAnimationFrame to call extrapolatePosition for each traffic marker at 60fps, creating smooth motion between 3-second API updates.
    Rendering Impact:
    7. Map Layer Management
    Layer Z-Index Organization
    Key Principles:
      Live traffic icons render above advisory overlays Advisory areas use semi-transparent fills (20-30% opacity) Separate live traffic markers from advisory polygons in different layer groups GeoJSON coordinates are [longitude, latitude]—convert to your map library's format Use click handlers on live traffic; avoid on advisory overlays to prevent blocking map interaction
        Leaflet: L.layerGroup() with custom panes and z-index Mapbox GL JS: Layer IDs with beforeId parameter Google Maps: setZIndex() on overlay objects OpenLayers: Z-index in layer style definitions
        8. Traffic Aging and Expiry
        Data Freshness Management
        Advisory UAV Traffic:
        Age State Visualization
        Uncertainty Visualization:
        Implementation Approach:
        8.9. Visual Design Guidelines
        Traffic Icon States
        Solid icon
        Full color
        70% opacity
        Subtle pulse
        Traffic Categorization
        9.10. Icon Assets
        Download: aircraft_icons.zip
        Beacon Type to Icon Mapping:
        UNKNOWN dot.svg —
        STATIC_OBJECT dot.svg —
        GLIDER glider.svg —
        PARA_GLIDER para_glider.svg —
        HAND_GLIDER hand_glider.svg —
        PARA_MOTOR para_motor.svg —
        PARACHUTE parachute.svg —
        MOTORPLANE aircraft.svg —
        JET heavy_aircraft.svg —
        AIRSHIP airship.svg —
        BALLOON ballon.svg —
        UAV uav.svg —
        PAV pav.svg —
        MILITARY military.svg —
        10.11. Configuration Reference
        Timing Parameters
        Parameter Value Rationale
        11.12. Reference Implementation
