Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Radius Queries
Trade-offs:
Viewport Padding (Overscan)
To avoid this, extend the queried viewport 5–15% beyond the visible map area. This technique—commonly referred to as overscan allows the client to pre-fetch traffic that is about to enter the screen.
Implementation Example:
  return {
Polling Frequency
Network Optimization:
The SafeSky UAV API returnscan return two different kinds of UAV-related traffic, and it is important to treat them differently in both your UI and your safety logic:
    Live Traffic: real-time objects with a precise position (a tracked point). Advisory Traffic: declared or expected UAV operation areas (an active zone with declared maximum altitude, not a track).
    These two distincttraffic types of UAV traffic, each withserve different dataoperational modelspurposes. andLive displaytraffic requirements.answers the question “Where is it right now?”, while advisory traffic answers “UAV activity is taking place in this area.”
    DataWhat Sourceit represents Real-timeActively telemetrytracked fromaircraft activeor UAVsUAV Pre-declaredDeclared activityUAV areasoperation area
    Geometry Point (latitude / longitude) GeoJSON Polygon Precision Exact positionHigh (lat/lng)GPS / transponder based) Area-basedMedium to low (polygonarea orof point + radius)activity) Update Frequencyfrequency 1-Typically every 1–5 seconds Typically ~1 minute UseUser Caseinterpretation Track“This UAVsobject inis real-timehere flightand moving” Show“UAV plannedactivity oris ongoingoccuring operationshere” TransponderRendering Typemodel ADS-B,Aircraft/UAV FLARM,icon ADS-L,with or customheading ADVISORYArea overlay (no heading) PositionPrimary Accuracypurpose HighTactical (GPS-based)awareness & deconfliction LowStrategic (areaawareness indicator)& caution
    3.1 Live Traffic Response Model
    Live traffic represents UAVsaircraft and aircraftUAVs transmittingthat real-timeare positionactively data:broadcasting telemetry, such as ADS-B, FLARM, ADS-L, or UAV telemetry. These objects should be treated as moving tracked targets.
    Typical characteristics:
      Precise latitude and longitude Motion data such as ground_speed, course (and sometimes vertical_rate) A recent last_update timestamp A status such as AIRBORNE, GROUNDED, or INACTIVE Optional accuracy information
        "call_sign": "FlyingFrog",
        "accuracy": 10
      KeyRendering Fields:guidance for live traffic:
      • PreciseRender latitudeas anda longitudepoint coordinatessymbol (UAV icon).
      • Real-timeRotate motionthe data:icon ground_speed,according to course, vertical_rate.
      • HighUse positionsmooth accuracymotion (typicallyextrapolation <100m)/ dead reckoning) between polling cycles.
      • Status:Apply data ageing rules (fade → uncertainty → removal) based on AIRBORNElast_update, GROUNDED, or INACTIVE.
      3.2 Advisory Traffic Response(Operational ModelAreas)
      Advisory traffic represents declared UAV operations rather than tracked objects. It indicates areas where UAV activity is planned or ongoing, even when no live telemetry is available.
      Advisory traffic is returned as a GeoJSON FeatureCollection, format:where each feature describes an operational area:
        Polygon geometry: explicit area boundaries. Point geometry + max_distance: centre point with an operational radius.
                "id": "Advisory123",
                "call_sign": "UAV_Alpha",
                "last_update": 1738142598,
                "max_altitude": 150,
                "remarks": "Surveying area"
                "coordinates": [
                    [4.39201, 50.69378],
                    [4.39300, 50.69400],
                    [4.39400, 50.69500],
                    [4.39201, 50.69378]
        KeyRendering Features:guidance for advisory traffic:
        Can contain Polygon or Point geometry types max_altitude represents maximum operational altitude max_distance property (for Point geometry) defines operational radius Render as an area overlay (polygon or circle). Use semi-transparent fills to preserve map readability. Display a label with call_sign (or ID) and max_altitude. Do not render heading indicators, motion vectors, or animations. Update less frequently than live traffic (advisories change slowly).
        Key rule: advisory traffic is a risk / awareness zone, not a precise position.
        3.3 Common Pitfalls
          Do not extrapolate advisory areas. They are static operational zones. Do not use identical colours or styles for live and advisory traffic. Do not apply the same expiry timing to live and advisory data.
            Display live traffic above advisory areas (higher z-index). Use clearly distinct colours and shapes orfor circulareach areastraffic ontype. theOn mapuser interaction:
              Live traffic: show call sign, altitude, speed, last update, and source. Advisory traffic: show operation name, max altitude, remarks, and last update. Apply different ageing thresholds:
                Live traffic expires quickly to avoid stale precision. Advisory traffic persists longer but updates infrequently.
                Display Recommendations
                Displaying Live Traffic
                Visual Styling:
                Implementation:
                Displaying Advisory Traffic
                Visual Styling:
                • Z-Index: Below live traffic
                      const polygon = new Polygon({
                        coordinates: [coordinates],
                        stroke: 'rgb(255, 140, 0)',
                        strokeWidth: 2
                      const label = new Label({
                        position: centroid,
                        style: {
                          padding: '4px',
                          borderRadius: '4px'
                      return [polygon, label];
                      const circle = new Circle({
                        radius: radius,
                        strokeWidth: 2
                      return circle;
                  }).flat();
                  return features;
                  let x = 0, y = 0;
                    x += coord[0];
                    y += coord[1];
                Rendering Best Practices:
                User Experience Guidelines:
                    "id": "hx-137105",
                    "latitude": 63.41303,
                    "longitude": 10.11205,
                    "accuracy": 1852,
                    "call_sign": "HWX137105",
                    "last_update": 1766068287,
                    "altitude": 231,
                    "id": "096E2863",
                    "latitude": 59.17081,
                    "longitude": 9.5268,
                    "beacon_type": "HELICOPTER",
                    "vertical_rate": 45,
                    "call_sign": "ROTORWING 30",
                    "transponder_type": "ADS-BI",
                    "last_update": 1766068285,
                    "altitude": 450,
                    "altitude_accuracy": 10,
                    "course": 315,
                    "ground_speed": 54,
                4. Publishing UAV Information
                POST /v1/uav
                Performance Comparison:
                Individual 10 10 ~4KB 10× RTT
                Batch 10 1 ~400B 1× RTT
                Key Benefits:
                    "altitude": 120,
                    "ground_speed": 12,
                    "latitude": 48.87012,
                    "longitude": 2.64188,
                    "altitude": 115,
                    "course": 210,
                    "ground_speed": 10,
                5. Pre-Flight Visibility
                GROUNDED Status Broadcasting
                  "last_update": 1734537600
                Operational Rationale:
                6. Smooth Motion Rendering
                Algorithm:
                  return {
                Rendering Impact:
                7. Traffic Aging and Expiry
                Data Freshness Management
                Advisory UAV Traffic:
                Age State Visualization
                Uncertainty Visualization:
                Implementation Approach:
                8. Visual Design Guidelines
                Traffic Icon States
                Solid icon
                Full color
                70% opacity
                Subtle pulse
                Traffic Categorization
                9. Icon Assets
                Download: aircraft_icons.zip
                Beacon Type to Icon Mapping:
                UNKNOWN dot.svg —
                STATIC_OBJECT dot.svg —
                GLIDER glider.svg —
                PARA_GLIDER para_glider.svg —
                HAND_GLIDER hand_glider.svg —
                PARA_MOTOR para_motor.svg —
                PARACHUTE parachute.svg —
                MOTORPLANE aircraft.svg —
                JET heavy_aircraft.svg —
                AIRSHIP airship.svg —
                BALLOON ballon.svg —
                UAV uav.svg —
                PAV pav.svg —
                MILITARY military.svg —
                10. Configuration Reference
                Timing Parameters
                Parameter Value Rationale
                11. Reference Implementation
