Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Efficient traffic retrieval is essential for a responsive UI and predictable backend load. The SafeSky UAV API supports two complementary ways to retrieve surrounding traffic using the same endpoint (GET /v1/uav):
    Viewport Query (bounding box): best for map rendering (what’s visible on screen). Radius Query (circle around a point): best for proximity logic (alerts, local awareness around a UAV/operator).
    Viewport-Based Queries
      Match how mapping SDKs work (screen = rectangle) Avoid fetching large off-screen traffic that won’t be rendered Scale naturally with zoom level (smaller bounds when zoomed in, larger when zoomed out)
      Radius Queries
      Use radius queries when your logic is centred around a specific point (e.g., UAV position, operator location, mission centroid) and you want all traffic within a fixed distance, regardless of the current map viewport.
        Proximity / safety alerting around a UAV (or operator) position Backend checks independent of UI viewport (e.g., monitoring a mission corridor) Applications without a map, or where map rendering is secondary
        Trade-offs:
          A radius query may return aircraft outside the currently visible map area (if you also render a map) If used for rendering, you may want client-side filtering to prevent clutter outside the viewport
          Viewport Padding (Overscan)
          Implementation Example:
            return {
          Benefits:
          Polling Frequency
          Network Optimization:
          Live Traffic Response Model
            "call_sign": "FlyingFrog",
            "accuracy": 10
          Key Fields:
                  "id": "Advisory123",
                  "call_sign": "UAV_Alpha",
                  "last_update": 1738142598,
                  "max_altitude": 150,
                  "remarks": "Surveying area"
                  "coordinates": [
                      [4.39201, 50.69378],
                      [4.39300, 50.69400],
                      [4.39400, 50.69500],
                      [4.39201, 50.69378]
          Key Features:
          Display Recommendations
          Displaying Live Traffic
          Visual Styling:
          Implementation:
          Displaying Advisory Traffic
          Visual Styling:
          • Z-Index: Below live traffic
                const polygon = new Polygon({
                  coordinates: [coordinates],
                  stroke: 'rgb(255, 140, 0)',
                  strokeWidth: 2
                const label = new Label({
                  position: centroid,
                  style: {
                    padding: '4px',
                    borderRadius: '4px'
                return [polygon, label];
                const circle = new Circle({
                  radius: radius,
                  strokeWidth: 2
                return circle;
            }).flat();
            return features;
            let x = 0, y = 0;
              x += coord[0];
              y += coord[1];
          Rendering Best Practices:
          User Experience Guidelines:
              "id": "hx-137105",
              "latitude": 63.41303,
              "longitude": 10.11205,
              "accuracy": 1852,
              "call_sign": "HWX137105",
              "last_update": 1766068287,
              "altitude": 231,
              "id": "096E2863",
              "latitude": 59.17081,
              "longitude": 9.5268,
              "beacon_type": "HELICOPTER",
              "vertical_rate": 45,
              "call_sign": "ROTORWING 30",
              "transponder_type": "ADS-BI",
              "last_update": 1766068285,
              "altitude": 450,
              "altitude_accuracy": 10,
              "course": 315,
              "ground_speed": 54,
          4. Publishing UAV Information
          POST /v1/uav
          Performance Comparison:
          Individual 10 10 ~4KB 10× RTT
          Batch 10 1 ~400B 1× RTT
          Key Benefits:
              "altitude": 120,
              "ground_speed": 12,
              "latitude": 48.87012,
              "longitude": 2.64188,
              "altitude": 115,
              "course": 210,
              "ground_speed": 10,
          5. Pre-Flight Visibility
          GROUNDED Status Broadcasting
            "last_update": 1734537600
          Operational Rationale:
          6. Smooth Motion Rendering
          Algorithm:
            return {
          Rendering Impact:
          7. Traffic Aging and Expiry
          Data Freshness Management
          Advisory UAV Traffic:
          Age State Visualization
          Uncertainty Visualization:
          Implementation Approach:
          8. Visual Design Guidelines
          Traffic Icon States
          Solid icon
          Full color
          70% opacity
          Subtle pulse
          Traffic Categorization
          9. Icon Assets
          Download: aircraft_icons.zip
          Beacon Type to Icon Mapping:
          UNKNOWN dot.svg —
          STATIC_OBJECT dot.svg —
          GLIDER glider.svg —
          PARA_GLIDER para_glider.svg —
          HAND_GLIDER hand_glider.svg —
          PARA_MOTOR para_motor.svg —
          PARACHUTE parachute.svg —
          MOTORPLANE aircraft.svg —
          JET heavy_aircraft.svg —
          AIRSHIP airship.svg —
          BALLOON ballon.svg —
          UAV uav.svg —
          PAV pav.svg —
          MILITARY military.svg —
          10. Configuration Reference
          Timing Parameters
          Parameter Value Rationale
          11. Reference Implementation
