Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
  return {
Benefits:
Polling Frequency
Network Optimization:
Live Traffic Response Model
  "call_sign": "FlyingFrog",
  "accuracy": 10
Key Fields:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
Key Features:
Display Recommendations
Displaying Live Traffic
Visual Styling:
Implementation:
Displaying Advisory Traffic
Visual Styling:
  • Z-Index: Below live traffic
      const polygon = new Polygon({
        coordinates: [coordinates],
        stroke: 'rgb(255, 140, 0)',
        strokeWidth: 2
      const label = new Label({
        position: centroid,
        style: {
          padding: '4px',
          borderRadius: '4px'
      return [polygon, label];
      const circle = new Circle({
        radius: radius,
        strokeWidth: 2
      return circle;
  }).flat();
  return features;
  let x = 0, y = 0;
    x += coord[0];
    y += coord[1];
Rendering Best Practices:
User Experience Guidelines:
    "id": "hx-137105",
    "latitude": 63.41303,
    "longitude": 10.11205,
    "accuracy": 1852,
    "call_sign": "HWX137105",
    "last_update": 1766068287,
    "altitude": 231,
    "id": "096E2863",
    "latitude": 59.17081,
    "longitude": 9.5268,
    "beacon_type": "HELICOPTER",
    "vertical_rate": 45,
    "call_sign": "ROTORWING 30",
    "transponder_type": "ADS-BI",
    "last_update": 1766068285,
    "altitude": 450,
    "altitude_accuracy": 10,
    "course": 315,
    "ground_speed": 54,
4. Publishing UAV Information
POST /v1/uav
Performance Comparison:
Individual 10 10 ~4KB 10× RTT
Batch 10 1 ~400B 1× RTT
Key Benefits:
    "altitude": 120,
    "ground_speed": 12,
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
5. Pre-Flight Visibility
GROUNDED Status Broadcasting
  "last_update": 1734537600
Operational Rationale:
6. Smooth Motion Rendering
Algorithm:
  return {
Rendering Impact:
7. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic:
Age State Visualization
Uncertainty Visualization:
Implementation Approach:
8. Visual Design Guidelines
Traffic Icon States
Solid icon
Full color
70% opacity
Subtle pulse
Traffic Categorization
9. Icon Assets
Download: aircraft_icons.zip
Beacon Type to Icon Mapping:
UNKNOWN dot.svg —
STATIC_OBJECT dot.svg —
GLIDER glider.svg —
PARA_GLIDER para_glider.svg —
HAND_GLIDER hand_glider.svg —
PARA_MOTOR para_motor.svg —
PARACHUTE parachute.svg —
MOTORPLANE aircraft.svg —
JET heavy_aircraft.svg —
AIRSHIP airship.svg —
BALLOON ballon.svg —
UAV uav.svg —
PAV pav.svg —
MILITARY military.svg —
10. Configuration Reference
Timing Parameters
Parameter Value Rationale
11. Reference Implementation
