Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
  return {
Benefits:
Polling Frequency
Rationale:
    Aircraft moving at 100 knots travel ~150 meters in 3 seconds 3-second updates provide adequate situational awareness while reducing server load Reduces bandwidth consumption by 66% compared to 1-second polling Client-side extrapolation maintains smooth visual rendering between updates Acceptable load for both mobile and web clients with lower data usage
    Network Optimization:
    Live Traffic Response Model
      "call_sign": "FlyingFrog",
      "accuracy": 10
    Key Fields:
            "id": "Advisory123",
            "call_sign": "UAV_Alpha",
            "last_update": 1738142598,
            "max_altitude": 150,
            "remarks": "Surveying area"
            "coordinates": [
                [4.39201, 50.69378],
                [4.39300, 50.69400],
                [4.39400, 50.69500],
                [4.39201, 50.69378]
    Key Features:
    Display Recommendations
    Displaying Live Traffic
    Visual representation:
    Implementation:
    Displaying Advisory Traffic
    Visual Styling:
    • Z-Index: Below live traffic
          const polygon = new Polygon({
            coordinates: [coordinates],
            stroke: 'rgb(255, 140, 0)',
            strokeWidth: 2
          const label = new Label({
            position: centroid,
            style: {
              padding: '4px',
              borderRadius: '4px'
          return [polygon, label];
          const circle = new Circle({
            radius: radius,
            strokeWidth: 2
          return circle;
      }).flat();
      return features;
      let x = 0, y = 0;
        x += coord[0];
        y += coord[1];
    Rendering Best Practices:
    User Experience Guidelines:
        "id": "hx-137105",
        "latitude": 63.41303,
        "longitude": 10.11205,
        "accuracy": 1852,
        "call_sign": "HWX137105",
        "last_update": 1766068287,
        "altitude": 231,
        "id": "096E2863",
        "latitude": 59.17081,
        "longitude": 9.5268,
        "beacon_type": "HELICOPTER",
        "vertical_rate": 45,
        "call_sign": "ROTORWING 30",
        "transponder_type": "ADS-BI",
        "last_update": 1766068285,
        "altitude": 450,
        "altitude_accuracy": 10,
        "course": 315,
        "ground_speed": 54,
    4. Publishing UAV Information
    POST /v1/uav
    Performance Comparison:
    Individual 10 10 ~4KB 10× RTT
    Batch 10 1 ~400B 1× RTT
    Key Benefits:
        "altitude": 120,
        "ground_speed": 12,
        "latitude": 48.87012,
        "longitude": 2.64188,
        "altitude": 115,
        "course": 210,
        "ground_speed": 10,
    5. Pre-Flight Visibility
    GROUNDED Status Broadcasting
      "last_update": 1734537600
    Operational Rationale:
    6. Smooth Motion Rendering
    Algorithm:
      return {
    Rendering Impact:
    7. Traffic Aging and Expiry
    Data Freshness Management
    Advisory UAV Traffic
    Age State Visualization
    Uncertainty Visualization
    Implementation Approach:
    8. Visual Design Guidelines
    Traffic Icon States
    Data Freshness States:
    Traffic Categorization
    9. Icon Assets
    Download: aircraft.zip
    Package Contents:
    Usage Recommendations:
    10. Configuration Reference
    Timing Parameters
    Parameter Value Rationale
    11. Reference Implementation
