Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
  return {
Benefits:
Polling Frequency
Rationale:
  • Aircraft moving at 100 knots travel ~150 meters in 3 seconds
  • 3-second updates provide adequate situational awareness while reducing server load
  • Reduces bandwidth consumption by 66% compared to 1-second polling
  • Client-side extrapolation maintains smooth visual rendering between updates
  • Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
Live Traffic Response Model
  "call_sign": "FlyingFrog",
  "accuracy": 10
Key Fields:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
Key Features:
Display Recommendations
Displaying Live Traffic
Visual representation:
Implementation:
Displaying Advisory Traffic
Visual Styling:
  • Z-Index: Below live traffic
      const polygon = new Polygon({
        coordinates: [coordinates],
        stroke: 'rgb(255, 140, 0)',
        strokeWidth: 2
      const label = new Label({
        position: centroid,
        style: {
          padding: '4px',
          borderRadius: '4px'
      return [polygon, label];
      const circle = new Circle({
        radius: radius,
        strokeWidth: 2
      return circle;
  }).flat();
  return features;
  let x = 0, y = 0;
    x += coord[0];
    y += coord[1];
Rendering Best Practices:
User Experience Guidelines:
    "id": "hx-137105",
    "latitude": 63.41303,
    "longitude": 10.11205,
    "accuracy": 1852,
    "call_sign": "HWX137105",
    "last_update": 1766068287,
    "altitude": 231,
    "id": "096E2863",
    "latitude": 59.17081,
    "longitude": 9.5268,
    "beacon_type": "HELICOPTER",
    "vertical_rate": 45,
    "call_sign": "ROTORWING 30",
    "transponder_type": "ADS-BI",
    "last_update": 1766068285,
    "altitude": 450,
    "altitude_accuracy": 10,
    "course": 315,
    "ground_speed": 54,
4. Publishing UAV Information
POST /v1/uav
Performance Comparison:
Individual 10 10 ~4KB 10× RTT
Batch 10 1 ~400B 1× RTT
Key Benefits:
    "altitude": 120,
    "ground_speed": 12,
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
4.2 Advisory Area Publishing
Endpoint: POST /v1/advisory
Use this when you want to declare planned operation areas without live telemetry (e.g., scheduled operations, inspection zones).
POST /v1/advisory
Publishing Frequency: ~1 minute (advisory areas change infrequently)
Request Format: GeoJSON FeatureCollection
Advisory areas use the widely-adopted GeoJSON format, which allows you to define operation areas as:
    Points with radius (max_distance property) Polygons (closed coordinate arrays)
    Example 1: Point-Based Advisory
    Publish a circular operation area using a point and radius:
            "id": "advisory_001",
            "call_sign": "Survey_Alpha",
            "max_distance": 500,
            "remarks": "Railway inspection"
            "type": "Point",
            "coordinates": [4.39201, 50.69378]
    Example 2: Polygon-Based Advisory
    Publish a complex operation area using a polygon:
            "id": "advisory_002",
            "max_altitude": 120,
            "remarks": "Powerline inspection"
            "coordinates": [
                [4.39201, 50.69378]
    Required Properties
    Property Type Required Description id string Yes Unique identifier for the advisory call_sign string No Call sign for identification last_update long Yes Timestamp in seconds since epoch (UTC) max_altitude int Yes Maximum altitude in meters AMSL max_distance int Yes (for Point) Radius in meters for point-based advisories remarks string No Free text description of the operation
    Important Notes:
      When using Point geometry, the max_distance property is required When using Polygon geometry, coordinates must form a closed loop (first and last coordinate must be identical) You can publish multiple advisories in a single request by adding multiple features to the FeatureCollection Stop publishing an advisory when the operation is complete (advisories expire automatically)
        201 Created: Advisory published successfully 400 Bad Request: Invalid GeoJSON or authentication failure
        5. Pre-Flight Visibility
        GROUNDED Status Broadcasting
          "last_update": 1734537600
        Operational Rationale:
        6. Smooth Motion Rendering
        Algorithm:
          return {
        Rendering Impact:
        7. Traffic Aging and Expiry
        Data Freshness Management
        Advisory UAV Traffic
        Age State Visualization
        Uncertainty Visualization
        Implementation Approach:
        8. Visual Design Guidelines
        Traffic Icon States
        Data Freshness States:
        Traffic Categorization
        9. Icon Assets
        Download: aircraft.zip
        Package Contents:
        Usage Recommendations:
        10. Configuration Reference
        Timing Parameters
        Parameter Value Rationale
        11. Reference Implementation
