Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
│ Traffic Retrieval │ │ UAV Telemetry │
│ Application State/Map │
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
return {
Benefits:
Polling Frequency
Rationale:
- Aircraft moving at 100 knots travel ~150 meters in 3 seconds
- 3-second updates provide adequate situational awareness while reducing server load
- Reduces bandwidth consumption by 66% compared to 1-second polling
- Client-side extrapolation maintains smooth visual rendering between updates
- Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
- Consider compression (gzip) for responses
| Characteristic | Live Traffic | Advisory Traffic |
| Data Source | Real-time telemetry from active UAVs | Pre-declared activity areas |
| Precision | Exact position (lat/lng) | Area-based (polygon or point + radius) |
| Update Frequency | 1-5 seconds | ~1 minute |
| Use Case | Track UAVs in real-time flight | Show planned or ongoing operations |
| Transponder Type | ADS-B, FLARM, ADS-L, or custom |
ADVISORY |
| Position Accuracy | High (GPS-based) | Low (area indicator) |
Live Traffic Response Model
"call_sign": "FlyingFrog",
"accuracy": 10
Key Fields:
- Precise
latitudeandlongitudecoordinates - Real-time motion data:
ground_speed,course,vertical_rate - High position
accuracy(typically <100m) - Status:
AIRBORNE,GROUNDED, orINACTIVE
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
Key Features:
- Full GeoJSON FeatureCollection format
- Can contain Polygon or Point geometry types
max_altituderepresents maximum operational altitudemax_distanceproperty (for Point geometry) defines operational radius- Render as polygon shapes or circular areas on the map
Display Recommendations
Displaying Live Traffic
Visual representation:
Implementation:
- Use standard aircraft icons (see Section 9)
- Apply position extrapolation (see Section 6)
- Update icon rotation based on
course - Display motion vector or heading indicator
Displaying Advisory Traffic
Visual Styling:
- Fill: Semi-transparent orange/amber (20-30% opacity)
- Stroke: Solid distinct color (e.g.,
rgb(255, 140, 0)) - Label: Show call_sign and max_altitude
- Z-Index: Below live traffic
- No heading indicator: Advisory areas are static zones
const polygon = new Polygon({
coordinates: [coordinates],
stroke: 'rgb(255, 140, 0)',
strokeWidth: 2
const label = new Label({
position: centroid,
style: {
padding: '4px',
borderRadius: '4px'
return [polygon, label];
const circle = new Circle({
radius: radius,
strokeWidth: 2
return circle;
}).flat();
return features;
let x = 0, y = 0;
x += coord[0];
y += coord[1];
Rendering Best Practices:
- Coordinate Order: GeoJSON uses
[longitude, latitude]order—ensure your mapping library expects this format - Closed Polygons: The first and last coordinates are identical in GeoJSON; some libraries auto-close, others don't
- Multi-Polygon Support: If advisories can have holes or multiple parts, handle
MultiPolygongeometry type - Simplification: For complex polygons with many vertices, consider simplification at high zoom levels for performance
- Label Placement: Position labels at the polygon centroid or largest interior point to avoid edge placement
- Point Geometry: When rendering Point-based advisories, use the
max_distanceproperty as the circle radius
- Users must immediately recognize advisory areas as zones of potential activity, not exact positions
- Never render advisory traffic with precise aircraft icons that imply real-time tracking
- Always show the operational radius/area visually
- Use different colors/styles to distinguish from live traffic
User Experience Guidelines:
- Hover/Click Info: Display call_sign, max_altitude, remarks (if available), and last_update timestamp
- Opacity: Use semi-transparent fills (20-30% opacity) to avoid obscuring map features
- Z-Index: Render advisory areas below live traffic to maintain priority
- Update Frequency: Advisory areas change infrequently; avoid aggressive re-rendering
"id": "3423C3",
"accuracy": 10,
"id": "UAV456",
"latitude": 48.87012,
"longitude": 2.64188,
"transponder_type": "ADS-L",
"call_sign": "DRONE1",
"last_update": 1733412795,
"altitude": 120,
"ground_speed": 15,
"course": 180,
"accuracy": 5,
4. Publishing UAV Information
POST /v1/uav
Performance Comparison:
Key Benefits:
"altitude": 120,10554,
"ground_speed": 12,237,
"last_update"id": 1733412793"3423C3"
"id": "UAV2"hx-137105",
"latitude": 48.87012,63.41303,
"longitude": 2.64188,10.11205,
"accuracy": 1852,
"call_sign": "HWX137105",
"last_update": 1766068287,
"altitude": 115,231,
"course": 210,0,
"ground_speed": 10,0,
"id": "096E2863",
"latitude": 59.17081,
"longitude": 9.5268,
"beacon_type": "HELICOPTER",
"vertical_rate": 45,
"call_sign": "ROTORWING 30",
"transponder_type": "ADS-BI",
"last_update": 17334127931766068285,
"altitude": 450,
"altitude_accuracy": 10,
"course": 315,
"ground_speed": 54,
4.2 Advisory Area Publishing
Endpoint: POST /v1/advisory
Use this when you want to declare planned operation areas without live telemetry (e.g., scheduled operations, inspection zones).
POST /v1/advisory
Publishing Frequency: ~1 minute (advisory areas change infrequently)
Request Format: GeoJSON FeatureCollection
Advisory areas use the widely-adopted GeoJSON format, which allows you to define operation areas as:
- Points with radius (
max_distanceproperty) - Polygons (closed coordinate arrays)
Example 1: Point-Based Advisory
Publish a circular operation area using a point and radius:
"id": "advisory_001",
"call_sign": "Survey_Alpha",
"max_distance": 500,
"remarks": "Railway inspection"
"type": "Point",
"coordinates": [4.39201, 50.69378]
Example 2: Polygon-Based Advisory
Publish a complex operation area using a polygon:
"id": "advisory_002",
"max_altitude": 120,
"remarks": "Powerline inspection"
"coordinates": [
[4.39201, 50.69378]
Required Properties
| Property | Type | Required | Description |
string | Yes | Unique identifier for the advisory |
call_sign |
string | No | Call sign for identification |
long | Yes | Timestamp in seconds since epoch (UTC) |
max_altitude |
int | Yes | Maximum altitude in meters AMSL |
max_distance |
int | Yes (for Point) | Radius in meters for point-based advisories |
remarks |
string | No | Free text description of the operation |
Important Notes:
- When using Point geometry, the
max_distanceproperty is required - When using Polygon geometry, coordinates must form a closed loop (first and last coordinate must be identical)
- You can publish multiple advisories in a single request by adding multiple features to the FeatureCollection
- Stop publishing an advisory when the operation is complete (advisories expire automatically)
201 Created: Advisory published successfully400 Bad Request: Invalid GeoJSON or authentication failure
5. Pre-Flight Visibility
GROUNDED Status Broadcasting
"last_update": 1734537600
Operational Rationale:
State Transition:
6. Smooth Motion Rendering
Algorithm:
return {
Rendering Impact:
7. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic
Uncertainty Visualization
Implementation Approach:
8. Visual Design Guidelines
Traffic Icon States
Data Freshness States:
Traffic Categorization
9. Icon Assets
Download: aircraft.zip
Package Contents:
Usage Recommendations:
10. Configuration Reference
Timing Parameters
11. Reference Implementation
