Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
  return {
Benefits:
Polling Frequency
Rationale:
  • Aircraft moving at 100 knots travel ~150 meters in 3 seconds
  • 3-second updates provide adequate situational awareness while reducing server load
  • Reduces bandwidth consumption by 66% compared to 1-second polling
  • Client-side extrapolation maintains smooth visual rendering between updates
  • Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
Live Traffic Response Model
  "call_sign": "FlyingFrog",
  "accuracy": 10
Key Fields:
Advisory traffic representscan declaredbe UAVreturned operationin areastwo withoutformats livedepending telemetry:on how it was published:
Format 1: Simplified Point-Based (with accuracy radius)
  "id": "hx-137105",
  "latitude": 63.41303,
  "longitude": 10.11205,
  "call_sign": "HWX137105",
  "last_update": 1766068287,
  "altitude": 231,
  "accuracy": 1852,
Key Distinguishing Features:
  • transponder_type: "ADVISORY" identifies advisory traffic
  • Large accuracy value (typically 500-2000m) represents the operational radius
  • latitude/longitude indicate the center point of the advisory area
  • Render as a circular area on the map
Format 2: GeoJSON with Polygon Geometry
ground_speed{
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
and
Key courseFeatures:
are
typicallyFull 0GeoJSON (noFeatureCollection liveformat telemetry)Precise polygon boundaries defined by coordinate arrays max_altitude instead of altitude representsfield maximumRender operationalas altitudeexact polygon shape on the map
Important:Format Detection:
The
function accuracyisGeoJSONAdvisory(response) {
  return response.type === 'FeatureCollection';
function isSimplifiedAdvisory(traffic) {
  return traffic.transponder_type === 'ADVISORY';
 field for advisory traffic represents the radius of the operational area, not GPS precision.
Display Recommendations
Displaying Live Traffic
Visual representation:
Implementation:
Displaying Advisory Traffic
Advisory traffic should be rendered as area indicators rather than precise points:
points.
VisualThe representation:rendering •approach Shape:depends Circular area or polygon (if geometry available)
• Radius: Useon the accuracyresponse fieldformat.
value
Visual Styling (inapplies meters)to •both Style:formats):
    Fill: Semi-transparent fillorange/amber with(20-30% opacity) Stroke: Solid distinct bordercolor •(e.g., rgb(255, 140, 0)) Label: Show call_sign and max_altitude •Z-Index: Icon: Optional center marker (static, no heading) • Color: Distinct fromBelow live traffic (e.g.,No amber/yellow)heading indicator: Advisory areas are static zones
    ImplementationImplementation: Example:Circular Advisory (Format 1)
    function renderAdvisoryTraffic(renderCircularAdvisory(traffic) {
      if (traffic.transponder_type === 'ADVISORY') {
        // Render as circular area using accuracy as radius
        const circle = new Circle({
          center: [traffic.longitude, traffic.latitude],
          radius: traffic.accuracy, // meters
          fill: 'rgba(255, 165, 0, 0.2)25)', // Semi-transparent orange
          stroke: 'rgb(255, 140, 0)',
          strokeWidth: 2
        // Add center marker (optional)with label
        const marker = new Marker({
          position: [traffic.longitude, traffic.latitude],
          icon: 'advisory-icon', // Static icon (no rotation)
          label: {
            text: `${traffic.call_sign}\nMax Alt: ${traffic.altitude}m`,
            offset: [0, -10]
        return [circle, marker];
    Implementation: Polygon Advisory (Format 2)
          const polygon = new Polygon({
            coordinates: [coordinates],
            strokeWidth: 2
          const label = new Label({
            position: centroid,
            style: {
              padding: '4px',
              borderRadius: '4px'
          return [polygon, label];
            radius: radius,
            strokeWidth: 2
          return circle;
      }).flat();
      return features;
      let x = 0, y = 0;
        x += coord[0];
        y += coord[1];
    Polygon Rendering Best Practices:
      Coordinate Order: GeoJSON uses [longitude, latitude] order—ensure your mapping library expects this format Closed Polygons: The first and last coordinates are identical in GeoJSON; some libraries auto-close, others don't Multi-Polygon Support: If advisories can have holes or multiple parts, handle MultiPolygon geometry type Simplification: For complex polygons with many vertices, consider simplification at high zoom levels for performance Label Placement: Position labels at the polygon centroid or largest interior point to avoid edge placement
      Visual Comparison:
      Circular Advisory (Format 1):        Polygon Advisory (Format 2):
         │  UAV Zone │                       │  UAV   │
         │  150m AGL │                       │  Zone  ╰──╮
          ╲         ╱                         │ 150m    │
         (Perfect circle)                  (Exact boundaries)
      User Experience Guidelines:
      A typical API response may contain both types:
          "id": "3423C3",
          "accuracy": 10,
          "id": "hx-137105",
          "altitude": 231,
          "accuracy": 1852,
      Filtering Strategy:
      function categorizeTraffic(trafficArray) {
        const live = trafficArray.filter(t => t.transponder_type !== 'ADVISORY');
        const advisory = trafficArray.filter(t => t.transponder_type === 'ADVISORY');
        return { live, advisory };
      4. Publishing UAV Information
      POST /v1/uav
      Performance Comparison:
      Individual 10 10 ~4KB 10× RTT
      Batch 10 1 ~400B 1× RTT
      Key Benefits:
          "altitude": 120,
          "ground_speed": 12,
          "latitude": 48.87012,
          "longitude": 2.64188,
          "altitude": 115,
          "course": 210,
          "ground_speed": 10,
      4.2 Advisory Area Publishing
      Endpoint: POST /v1/advisory
      Use this when you want to declare planned operation areas without live telemetry (e.g., scheduled operations, inspection zones).
      POST /v1/advisory
      Publishing Frequency: ~1 minute (advisory areas change infrequently)
      Request Format: GeoJSON FeatureCollection
      Advisory areas use the widely-adopted GeoJSON format, which allows you to define operation areas as:
      • Points with radius (max_distance property)
      • Polygons (closed coordinate arrays)
      Example 1: Point-Based Advisory
      Publish a circular operation area using a point and radius:
              "id": "advisory_001",
              "call_sign": "Survey_Alpha",
              "max_distance": 500,
              "remarks": "Railway inspection"
              "type": "Point",
              "coordinates": [4.39201, 50.69378]
      Example 2: Polygon-Based Advisory
      Publish a complex operation area using a polygon:
              "id": "advisory_002",
              "max_altitude": 120,
              "remarks": "Powerline inspection"
              "coordinates": [
                  [4.39201, 50.69378]
      Required Properties
      Property Type Required Description
      id string Yes Unique identifier for the advisory
      call_sign string No Call sign for identification
      last_update long Yes Timestamp in seconds since epoch (UTC)
      max_altitude int Yes Maximum altitude in meters AMSL
      max_distance int Yes (for Point) Radius in meters for point-based advisories
      remarks string No Free text description of the operation
      Important Notes:
      • When using Point geometry, the max_distance property is required
      • When using Polygon geometry, coordinates must form a closed loop (first and last coordinate must be identical)
      • You can publish multiple advisories in a single request by adding multiple features to the FeatureCollection
      • Stop publishing an advisory when the operation is complete (advisories expire automatically)
      • 201 Created: Advisory published successfully
      • 400 Bad Request: Invalid GeoJSON or authentication failure
      5. Pre-Flight Visibility
      GROUNDED Status Broadcasting
        "last_update": 1734537600
      Operational Rationale:
      6. Smooth Motion Rendering
      Algorithm:
        return {
      Rendering Impact:
      7. Traffic Aging and Expiry
      Data Freshness Management
      Advisory UAV Traffic
      Age State Visualization
      Uncertainty Visualization
      Implementation Approach:
      8. Visual Design Guidelines
      Traffic Icon States
      Data Freshness States:
      Traffic Categorization
      9. Icon Assets
      Download: aircraft.zip
      Package Contents:
      Usage Recommendations:
      10. Configuration Reference
      Timing Parameters
      Parameter Value Rationale
      11. Reference Implementation
