Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
  return {
Benefits:
Polling Frequency
Rationale:
  • Aircraft moving at 100 knots travel ~150 meters in 3 seconds
  • 3-second updates provide adequate situational awareness while reducing server load
  • Reduces bandwidth consumption by 66% compared to 1-second polling
  • Client-side extrapolation maintains smooth visual rendering between updates
  • Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
Live Traffic Response Model
  "call_sign": "FlyingFrog",
  "accuracy": 10
Key Fields:
Advisory traffic represents declared UAV operation areas without live telemetry:
  "id": "hx-137105",
  "latitude": 63.41303,
  "longitude": 10.11205,
  "call_sign": "HWX137105",
  "last_update": 1766068287,
  "altitude": 231,
  "accuracy": 1852,
Key Distinguishing Features:
  • transponder_type: "ADVISORY" identifies advisory traffic
  • Large accuracy value (typically 500-2000m) represents the operational radius
  • latitude/longitude indicate the center point of the advisory area
  • ground_speed and course are typically 0 (no live telemetry)
  • altitude represents maximum operational altitude
Important: The accuracy field for advisory traffic represents the radius of the operational area, not GPS precision.
Display Recommendations
Displaying Live Traffic
Visual representation:
Implementation:
Displaying Advisory Traffic
Advisory traffic should be rendered as area indicators rather than precise points:
• Shape: Circular area or polygon (if geometry available)
• Radius: Use the accuracy field value (in meters)
• Style: Semi-transparent fill with distinct border
• Icon: Optional center marker (static, no heading)
• Color: Distinct from live traffic (e.g., amber/yellow)
function renderAdvisoryTraffic(traffic) {
  if (traffic.transponder_type === 'ADVISORY') {
    // Render as circular area
    const circle = new Circle({
      center: [traffic.longitude, traffic.latitude],
      radius: traffic.accuracy, // meters
      fill: 'rgba(255, 165, 0, 0.2)', // Semi-transparent orange
      stroke: 'rgb(255, 140, 0)',
      strokeWidth: 2
    // Add center marker (optional)
    const marker = new Marker({
      position: [traffic.longitude, traffic.latitude],
      icon: 'advisory-icon',
      label: `${traffic.call_sign}\nMax Alt: ${traffic.altitude}m`
    return [circle, marker];
User Experience Guidelines:
A typical API response may contain both types:
    "id": "3423C3",
    "accuracy": 10,
    "id": "hx-137105",
    "altitude": 231,
    "accuracy": 1852,
Filtering Strategy:
function categorizeTraffic(trafficArray) {
  const live = trafficArray.filter(t => t.transponder_type !== 'ADVISORY');
  const advisory = trafficArray.filter(t => t.transponder_type === 'ADVISORY');
  return { live, advisory };
4. Publishing UAV Information
POST /v1/uav
Performance Comparison:
Individual 10 10 ~4KB 10× RTT
Batch 10 1 ~400B 1× RTT
Key Benefits:
    "altitude": 120,
    "ground_speed": 12,
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
4.2 Advisory Area Publishing
Endpoint: POST /v1/advisory
Use this when you want to declare planned operation areas without live telemetry (e.g., scheduled operations, inspection zones).
POST /v1/advisory
Publishing Frequency: ~1 minute (advisory areas change infrequently)
Request Format: GeoJSON FeatureCollection
Advisory areas use the widely-adopted GeoJSON format, which allows you to define operation areas as:
  • Points with radius (max_distance property)
  • Polygons (closed coordinate arrays)
Example 1: Point-Based Advisory
Publish a circular operation area using a point and radius:
        "id": "advisory_001",
        "call_sign": "Survey_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "max_distance": 500,
        "remarks": "Railway inspection"
        "type": "Point",
        "coordinates": [4.39201, 50.69378]
Example 2: Polygon-Based Advisory
Publish a complex operation area using a polygon:
        "id": "advisory_002",
        "call_sign": "UAV_Alpha",
        "max_altitude": 120,
        "remarks": "Powerline inspection"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
Required Properties
Property Type Required Description
id string Yes Unique identifier for the advisory
call_sign string No Call sign for identification
last_update long Yes Timestamp in seconds since epoch (UTC)
max_altitude int Yes Maximum altitude in meters AMSL
max_distance int Yes (for Point) Radius in meters for point-based advisories
remarks string No Free text description of the operation
Important Notes:
  • When using Point geometry, the max_distance property is required
  • When using Polygon geometry, coordinates must form a closed loop (first and last coordinate must be identical)
  • You can publish multiple advisories in a single request by adding multiple features to the FeatureCollection
  • Stop publishing an advisory when the operation is complete (advisories expire automatically)
  • 201 Created: Advisory published successfully
  • 400 Bad Request: Invalid GeoJSON or authentication failure
5. Pre-Flight Visibility
GROUNDED Status Broadcasting
  "last_update": 1734537600
Operational Rationale:
6. Smooth Motion Rendering
Algorithm:
  return {
Rendering Impact:
7. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic
Age State Visualization
Uncertainty Visualization
Implementation Approach:
8. Visual Design Guidelines
Traffic Icon States
Data Freshness States:
Traffic Categorization
9. Icon Assets
Download: aircraft.zip
Package Contents:
Usage Recommendations:
10. Configuration Reference
Timing Parameters
Parameter Value Rationale
11. Reference Implementation
