Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
│ Traffic Retrieval │ │ UAV Telemetry │
│ Application State/Map │
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
return {
Benefits:
Polling Frequency
Rationale:
- Aircraft moving at 100 knots travel ~150 meters in 3 seconds
- 3-second updates provide adequate situational awareness while reducing server load
- Reduces bandwidth consumption by 66% compared to 1-second polling
- Client-side extrapolation maintains smooth visual rendering between updates
- Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
- Consider compression (gzip) for responses
ADS-B, FLARM, ADS-L, or custom
ADVISORY
Position Accuracy
High (GPS-based)
Low (area indicator)
Live Traffic Response Model
"call_sign": "FlyingFrog",
"accuracy": 10
Key Fields:
latitude and longitude coordinates
Real-time motion data: ground_speed, course, vertical_rate
High position accuracy (typically <100m)
Status: AIRBORNE, GROUNDED, or INACTIVE
Advisory traffic represents declared UAV operation areas without live telemetry:
"id": "hx-137105",
"latitude": 63.41303,
"longitude": 10.11205,
"call_sign": "HWX137105",
"last_update": 1766068287,
"altitude": 231,
"accuracy": 1852,
Key Distinguishing Features:
transponder_type: "ADVISORY" identifies advisory traffic
Large accuracy value (typically 500-2000m) represents the operational radius
latitude/longitude indicate the center point of the advisory area
ground_speed and course are typically 0 (no live telemetry)
altitude represents maximum operational altitude
Important: The accuracy field for advisory traffic represents the radius of the operational area, not GPS precision.
Display Recommendations
Displaying Live Traffic
Visual representation:
Implementation:
course
Display motion vector or heading indicator
Displaying Advisory Traffic
Advisory traffic should be rendered as area indicators rather than precise points:
• Shape: Circular area or polygon (if geometry available)
• Radius: Use the accuracy field value (in meters)
• Style: Semi-transparent fill with distinct border
• Icon: Optional center marker (static, no heading)
• Color: Distinct from live traffic (e.g., amber/yellow)
function renderAdvisoryTraffic(traffic) {
if (traffic.transponder_type === 'ADVISORY') {
// Render as circular area
const circle = new Circle({
center: [traffic.longitude, traffic.latitude],
radius: traffic.accuracy, // meters
fill: 'rgba(255, 165, 0, 0.2)', // Semi-transparent orange
stroke: 'rgb(255, 140, 0)',
strokeWidth: 2
// Add center marker (optional)
const marker = new Marker({
position: [traffic.longitude, traffic.latitude],
icon: 'advisory-icon',
label: `${traffic.call_sign}\nMax Alt: ${traffic.altitude}m`
return [circle, marker];
User Experience Guidelines:
A typical API response may contain both types:
"id": "3423C3",
"accuracy": 10,
"id": "hx-137105",
"altitude": 231,
"accuracy": 1852,
Filtering Strategy:
function categorizeTraffic(trafficArray) {
const live = trafficArray.filter(t => t.transponder_type !== 'ADVISORY');
const advisory = trafficArray.filter(t => t.transponder_type === 'ADVISORY');
return { live, advisory };
4. UAV Telemetry Publishing
Endpoint
POST /v1/uav
Performance Comparison:
Key Benefits:
"altitude": 120,
"ground_speed": 12,
"latitude": 48.87012,
"longitude": 2.64188,
"altitude": 115,
"course": 210,
"ground_speed": 10,
4.5. Pre-Flight Visibility
GROUNDED Status Broadcasting
"last_update": 1734537600
Operational Rationale:
State Transition:
5.6. Smooth Motion Rendering
Algorithm:
return {
Rendering Impact:
6.7. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic
Uncertainty Visualization
Implementation Approach:
7.8. Visual Design Guidelines
Traffic Icon States
Data Freshness States:
Traffic Categorization
8.9. Icon Assets
Download: aircraft.zip
Package Contents:
Usage Recommendations:
9.10. Configuration Reference
Timing Parameters
10.11. Reference Implementation
