Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Viewport Padding (Overscan)
Implementation Example:
  return {
Benefits:
Polling Frequency
Rationale:
  • Aircraft moving at 100 knots travel ~150 meters in 3 seconds
  • 3-second updates provide adequate situational awareness while reducing server load
  • Reduces bandwidth consumption by 66% compared to 1-second polling
  • Client-side extrapolation maintains smooth visual rendering between updates
  • Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
Live Traffic Response Model
  "call_sign": "FlyingFrog",
  "accuracy": 10
Key Fields:
Advisory traffic represents declared UAV operation areas without live telemetry:
  "id": "hx-137105",
  "latitude": 63.41303,
  "longitude": 10.11205,
  "call_sign": "HWX137105",
  "last_update": 1766068287,
  "altitude": 231,
  "accuracy": 1852,
Key Distinguishing Features:
  • transponder_type: "ADVISORY" identifies advisory traffic
  • Large accuracy value (typically 500-2000m) represents the operational radius
  • latitude/longitude indicate the center point of the advisory area
  • ground_speed and course are typically 0 (no live telemetry)
  • altitude represents maximum operational altitude
Important: The accuracy field for advisory traffic represents the radius of the operational area, not GPS precision.
Display Recommendations
Displaying Live Traffic
Visual representation:
Implementation:
Displaying Advisory Traffic
Advisory traffic should be rendered as area indicators rather than precise points:
• Shape: Circular area or polygon (if geometry available)
• Radius: Use the accuracy field value (in meters)
• Style: Semi-transparent fill with distinct border
• Icon: Optional center marker (static, no heading)
• Color: Distinct from live traffic (e.g., amber/yellow)
function renderAdvisoryTraffic(traffic) {
  if (traffic.transponder_type === 'ADVISORY') {
    // Render as circular area
    const circle = new Circle({
      center: [traffic.longitude, traffic.latitude],
      radius: traffic.accuracy, // meters
      fill: 'rgba(255, 165, 0, 0.2)', // Semi-transparent orange
      stroke: 'rgb(255, 140, 0)',
      strokeWidth: 2
    // Add center marker (optional)
    const marker = new Marker({
      position: [traffic.longitude, traffic.latitude],
      icon: 'advisory-icon',
      label: `${traffic.call_sign}\nMax Alt: ${traffic.altitude}m`
    return [circle, marker];
User Experience Guidelines:
A typical API response may contain both types:
    "id": "3423C3",
    "accuracy": 10,
    "id": "hx-137105",
    "altitude": 231,
    "accuracy": 1852,
Filtering Strategy:
function categorizeTraffic(trafficArray) {
  const live = trafficArray.filter(t => t.transponder_type !== 'ADVISORY');
  const advisory = trafficArray.filter(t => t.transponder_type === 'ADVISORY');
  return { live, advisory };
4. UAV Telemetry Publishing
Endpoint
POST /v1/uav
Performance Comparison:
Individual 10 10 ~4KB 10× RTT
Batch 10 1 ~400B 1× RTT
Key Benefits:
    "altitude": 120,
    "ground_speed": 12,
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
5. Pre-Flight Visibility
GROUNDED Status Broadcasting
  "last_update": 1734537600
Operational Rationale:
6. Smooth Motion Rendering
Algorithm:
  return {
Rendering Impact:
7. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic
Age State Visualization
Uncertainty Visualization
Implementation Approach:
8. Visual Design Guidelines
Traffic Icon States
Data Freshness States:
Traffic Categorization
9. Icon Assets
Download: aircraft.zip
Package Contents:
Usage Recommendations:
10. Configuration Reference
Timing Parameters
Parameter Value Rationale
11. Reference Implementation
