Best Practices
Overview
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
│ Traffic Retrieval │ │ UAV Telemetry Publisher │
│ Application State/Map │
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Technical Advantages:Advantages of Viewport Query vs Radius Query:
Performance Impact: At high zoom levels (city view), viewport queries can reduce payload size by 40-60% compared to radius-based approaches that cover the same visible area.
Viewport Padding (Overscan)
Implementation Example:
return {
Benefits:
Tuning Guidance: Use larger padding (12-15%) for high-speed traffic environments or slower network connections.
Polling Frequency
Rationale:
- Aircraft moving at 100 knots travel ~150 meters in 3 seconds
- 3-second updates provide adequate situational awareness while reducing server load
- Reduces bandwidth consumption by 66% compared to 1-second polling
- Client-side extrapolation maintains smooth visual rendering between updates
- Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
Implement exponential backoff for failed requests
3. UAV Telemetry Publishing
Endpoint
POST /v1/uav
Performance Comparison:
Key Benefits:
"altitude": 120,
"ground_speed": 12,
"last_update": 1733412793
"latitude": 48.87012,
"longitude": 2.64188,
"altitude": 115,
"course": 210,
"ground_speed": 10,
4. Pre-Flight Visibility
GROUNDED Status Broadcasting
"last_update": 1734537600
Operational Rationale:
State Transition:
5. Smooth Motion Rendering
Algorithm:
return {
Rendering Impact:
6. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic
Uncertainty Visualization
Implementation Approach:
7. Visual Design Guidelines
Traffic Icon States
Data Freshness States:
Uncertainty circle example:
Traffic Categorization
8. Icon Assets
Download: aircraft.zip
Package Contents:
Usage Recommendations:
9. Configuration Reference
Timing Parameters
10. Reference Implementation
