Best Practices
Overview
The SafeSky API enables developers to build production-grade air traffic awareness systems that display real-time positions of UAVs, helicopters, general aviation aircraft, and commercial traffic. This guide addresses the technical challenges of building responsive, scalable traffic layers that meet operational aviation standards.
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
│ Traffic Retrieval │ │ Telemetry Publisher │
│ Thread │ │ Thread │
│ Application State/Map │
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Technical Advantages:
Performance Impact: At high zoom levels (city view), viewport queries can reduce payload size by 40-60% compared to radius-based approaches that cover the same visible area.
Viewport Padding (Overscan)
Implementation Example:
return {
Benefits:
Tuning Guidance: Use larger padding (12-15%) for high-speed traffic environments or slower network connections.
Polling Frequency
Rationale:
- Aircraft moving at 100 knots travel ~150 meters in 3 seconds
- 3-second updates provide adequate situational awareness while reducing server load
- Reduces bandwidth consumption by 66% compared to 1-second polling
- Client-side extrapolation maintains smooth visual rendering between updates
- Acceptable load for both mobile and web clients with lower data usage
Network Optimization:
- Implement exponential backoff for failed requests
- Consider compression (gzip/brotli) for responses
- Use HTTP/2 or HTTP/3 where available for connection multiplexing
3. UAV Telemetry Publishing
Endpoint
POST /v1/uav
Performance Comparison:
Key Benefits:
- Atomic timestamps: All UAVs share consistent update time
"altitude": 120,
"ground_speed": 12,
"last_update": 1733412793
"latitude": 48.87012,
"longitude": 2.64188,
"altitude": 115,
"course": 210,
"ground_speed": 10,
4. Pre-Flight Visibility
GROUNDED Status Broadcasting
"last_update": 1734537600
Operational Rationale:
State Transition:
5. Smooth Motion Rendering
Algorithm:
return {
Rendering Impact:
6. Traffic Aging and Expiry
Data Freshness Management
Advisory UAV Traffic
Uncertainty Visualization
Implementation Approach:
7. Visual Design Guidelines
Traffic Icon States
Data Freshness States:
Uncertainty circle example:
Traffic Categorization
8. Icon Assets
Download: aircraft.zip
Package Contents:
Usage Recommendations:
9. Configuration Reference
Timing Parameters
10. Reference Implementation
Additional Resources
- API Reference: Full endpoint documentation and schemas
- Authentication Guide: HMAC signing and API key management
- Rate Limits: Request throttling and quota information
- Support: Technical support channels and community forums
