Best Practices
Overview
The SafeSky API enables developers to build production-grade air traffic awareness systems that display real-time positions of UAVs, helicopters, general aviation aircraft, and commercial traffic. This guide addresses the technical challenges of building responsive, scalable traffic layers that meet operational aviation standards.
Key Design Goals
1. Integration Architecture
Dual-Thread Pattern
│  Traffic Retrieval  │      │ Telemetry Publisher │
│      Thread         │      │      Thread         │
│ 1Hz polling         │      │ 1Hz transmission    │
Architectural Benefits:
2. Traffic Retrieval Strategy
Viewport-Based Queries
Technical Advantages:
Performance Impact: At high zoom levels (city view), viewport queries can reduce payload size by 40-60% compared to radius-based approaches that cover the same visible area.
Viewport Padding (Overscan)
Implementation Example:
  return {
Benefits:
Tuning Guidance: Use larger padding (12-15%) for high-speed traffic environments or slower network connections.
Polling Frequency
This frequency balances real-time awareness with reasonable bandwidth consumption.
Rationale:
  • Aircraft moving at 100 knots travel ~50 meters per second
  • 1-second updates provide smooth interpolation without perceptible lag
  • Aligns with aviation-grade situational awareness requirements
  • Acceptable load for both mobile and web clients
Network Optimization:
  • Implement exponential backoff for failed requests
  • Consider compression (gzip/brotli) for responses
  • Use HTTP/2 or HTTP/3 where available for connection multiplexing
3. UAV Telemetry Publishing
Endpoint
POST /v1/uav
Performance Comparison:
Individual 10 10 ~4KB 10× RTT
Batch 10 1 ~400B 1× RTT
Key Benefits:
  • Atomic timestamps: All UAVs share consistent update time
################ Example: Batch UAV Publish Payload
    "altitude": 120,
    "ground_speed": 12,
    "last_update": 1733412793
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
4. Pre-Flight Visibility
GROUNDED Status Broadcasting
  "last_update": 1734537600
Operational Rationale:
5. Smooth Motion Rendering
Traffic updates arrive at discrete 1-second intervals. To achieve smooth animation, implement dead reckoning between updates.
Algorithm:
  return {
Rendering Impact:
6. Traffic Aging and Expiry
Data Freshness Management
######## Advisory UAV Traffic
######## Real-Time Air Traffic (ADS-B, FLARM, ADS-L)
Age State Visualization
Uncertainty Visualization
Implementation Approach:
7. Visual Design Guidelines
Traffic Icon States
Data Freshness States:
Traffic Categorization
8. Icon Assets
Download: https://docs.safesky.app/downloads/iconsets
Package Contents:
Usage Recommendations:
9. Configuration Reference
Timing Parameters
Parameter Value Rationale
GET traffic (viewport) 1 second Optimal balance of real-time awareness and bandwidth
10. Reference Implementation
Additional Resources
  • API Reference: Full endpoint documentation and schemas
  • Authentication Guide: HMAC signing and API key management
  • Rate Limits: Request throttling and quota information
  • Support: Technical support channels and community forums
