Best Practices
This page provides developer-oriented best practices for integrating the SafeSky UAV API into custom mission control software, moving-map applications, or operational dashboards.
The objective is to build a smooth, scalable, and operationally correct traffic layer showing crewed aircraft, helicopters, and UAV activity in real time.
A live reference implementation using these principles is available at:
πŸ‘‰ https://live.safesky.app
A robust integration should maintain two independent execution threads:
1. Traffic Retrieval Thread
  • Responsible for fetching nearby air traffic
  • Uses GET /v1/uav
  • Updates the map continuously
2. UAV Publishing Thread
  • Responsible for publishing your UAV telemetry
  • Uses POST /v1/uav
  • Runs independently of traffic retrieval
Separating these concerns improves reliability, scalability, and error handling.
2. Retrieving Traffic for a Moving Map
Use Viewport-Based Queries
For map-based applications, always prefer viewport-based queries instead of radius-based searches.
Why viewport queries are preferred
  • Matches map rendering logic
  • Scales efficiently at all zoom levels
  • Avoids unnecessary off-screen traffic
  • Enables smooth pan & zoom interactions
Add a Safety Margin (Outset)
Always extend the viewport slightly beyond the visible map bounds.
This ensures:
  • Aircraft near screen edges are still fetched
  • No visual β€œpop-in” when panning
  • Better anticipation of fast-moving traffic
Fetching slightly more traffic than visible is intentional and recommended.
Polling Frequency
3. Publishing UAV Telemetry
Use the following endpoint to publish one or more UAVs:
POST /v1/uav
Publishing Frequency
  • Recommended POST interval: 1 second
Batch Publishing (Strongly Recommended)
If managing multiple UAVs simultaneously, always publish telemetry in batch using a single POST request.
Why batch publishing matters:
  • Reduced HTTP overhead
  • Lower latency
  • Consistent timestamps across UAVs
  • Better scalability for fleets and swarms
  • Aggregate all UAV telemetry updates per cycle
  • Send them together once per second
  • Avoid individual POSTs per UAV
    "altitude": 120,
    "ground_speed": 12,
    "last_update": 1733412793
    "latitude": 48.87012,
    "longitude": 2.64188,
    "altitude": 115,
    "course": 210,
    "ground_speed": 10,
4. Pre-Flight Visibility (Grounded Status)
Advertise Before Takeoff
Before takeoff, it is considered best practice to publish the UAV with:
status = GROUNDED
When:
  • Ideally 3–5 minutes before takeoff
Why:
  • Makes UAV activity visible to helicopters and crewed aircraft
  • Improves shared situational awareness
  • Mirrors aviation intent signaling
Switch to AIRBORNE immediately after takeoff.
5. Smooth Aircraft Motion (Client-Side Extrapolation)
Traffic updates arrive at discrete intervals. To avoid β€œjumping” icons:
Use extrapolation between updates
  • Predict position using:
    • Last known position
    • Ground speed
    • Course
  • Linearly extrapolate until the next update arrives
This creates:
  • Smooth, professional map rendering
  • Better perception of traffic flow
  • Reduced visual jitter
6. Traffic Ageing, Uncertainty & Expiry
Different traffic types have different lifetimes.
Advisory UAV Traffic
  • Valid up to 2 minutes after timestamp expiry
  • Should remain visible with appropriate visual indication
Other Air Traffic (ADS-B, FLARM, ADS-L, etc.)
Time since last update Recommended behavior
0–30 seconds Display normally
30–45 seconds Display with expanding uncertainty circle
>45 seconds Remove from display
Uncertainty Visualization
  • Show an expanding circle around last known position
  • Radius increases over time to reflect possible movement
  • Prevents false precision after signal loss
7. Visual Representation Best Practices
  • Solid icon: fresh data
  • Reduced opacity: aging data
  • Expanding uncertainty circle: signal degradation
  • Distinct icons per traffic category (UAV, helicopter, GA, jet)
8. Icon Sets
To simplify integration, SafeSky provides ready-to-use traffic icon sets optimised for map rendering.
πŸ“¦ Icon sets download (placeholder):
https://docs.safesky.app/downloads/iconsets
Includes:
  • SVG and PNG formats
  • Multiple sizes
  • Dark and light themes
Action Interval
GET traffic (viewport) 1 second
POST UAV telemetry 1 second
Pre-flight GROUNDED publish 3–5 minutes before takeoff
Start uncertainty 30 seconds
Discard traffic 45 seconds
10. Reference Implementation
A live example implementing all these best practices is available at:
