Best Practices
This page provides developer-oriented best practices for integrating the SafeSky UAV API into custom mission control software, moving-map applications, or operational dashboards.
The objective is to build a smooth, scalable, and operationally correct traffic layer showing crewed aircraft, helicopters, and UAV activity in real time.
A live reference implementation using these principles is available at: https://live.safesky.app
1. Recommended Integration Architecture
A robust integration should maintain two independent execution threads:
1. Traffic Retrieval Thread
- Responsible for fetching nearby air traffic
- Uses
GET /v1/uav - Updates the map continuously
2. UAV Publishing Thread
- Responsible for publishing your UAV telemetry
- Uses
POST /v1/uav - Runs independently of traffic retrieval
Separating these concerns improves reliability, scalability, and error handling.
2. Retrieving Traffic for a Moving Map
Use Viewport-Based Queries
For map-based applications, always prefer viewport-based queries instead of radius-based searches.
Why viewport queries are preferred
- Matches map rendering logic
- Scales efficiently at all zoom levels
- Avoids unnecessary off-screen traffic
- Enables smooth pan & zoom interactions
Add a Safety Margin (Outset)
Always extend the viewport slightly beyond the visible map bounds.
Recommended margin:
+5% to +15% on each side of the viewport
This ensures:
- Aircraft near screen edges are still fetched
- No visual “pop-in” when panning
- Better anticipation of fast-moving traffic
Fetching slightly more traffic than visible is intentional and recommended.
Polling Frequency
- Recommended GET interval: 1 second
- Provides smooth motion and near-real-time awareness
- Suitable for both UAV and crewed aircraft traffic
3. Publishing UAV Telemetry
Use the following endpoint to publish one or more UAVs:
POST /v1/uav
Publishing Frequency
- Recommended POST interval: 1 second
Batch Publishing (Strongly Recommended)
If managing multiple UAVs simultaneously, always publish telemetry in batch using a single POST request.
Why batch publishing matters:
- Reduced HTTP overhead
- Lower latency
- Consistent timestamps across UAVs
- Better scalability for fleets and swarms
Recommended approach:
- Aggregate all UAV telemetry updates per cycle
- Send them together once per second
- Avoid individual POSTs per UAV
"altitude": 120,
"ground_speed": 12,
"last_update": 1733412793
"latitude": 48.87012,
"longitude": 2.64188,
"altitude": 115,
"course": 210,
"ground_speed": 10,
4. Pre-Flight Visibility (Grounded Status)
Advertise Before Takeoff
Before takeoff, it is considered best practice to publish the UAV with:
status = GROUNDED
When:
- Ideally 3–5 minutes before takeoff
Why:
- Makes UAV activity visible to helicopters and crewed aircraft
- Improves shared situational awareness
- Mirrors aviation intent signaling
Switch to AIRBORNE immediately after takeoff.
5. Smooth Aircraft Motion (Client-Side Extrapolation)
Traffic updates arrive at discrete intervals. To avoid “jumping” icons:
Use extrapolation between updates
- Predict position using:
- Last known position
- Ground speed
- Course
- Linearly extrapolate until the next update arrives
This creates:
- Smooth, professional map rendering
- Better perception of traffic flow
- Reduced visual jitter
6. Traffic Ageing, Uncertainty & Expiry
Different traffic types have different lifetimes.
Advisory UAV Traffic
- Valid up to 2 minutes after timestamp expiry
- Should remain visible with appropriate visual indication
Other Air Traffic (ADS-B, FLARM, ADS-L, etc.)
| Time since last update | Recommended behavior |
| 0–30 seconds | Display normally |
| 30–45 seconds | Display with expanding uncertainty circle |
| >45 seconds | Remove from display |
Uncertainty Visualization
- Show an expanding circle around last known position
- Radius increases over time to reflect possible movement
- Prevents false precision after signal loss
7. Visual Representation Best Practices
Recommended visual cues:
- Solid icon: fresh data
- Reduced opacity: aging data
- Expanding uncertainty circle: signal degradation
- Distinct icons per traffic category (UAV, helicopter, GA, jet)
8. Icon Sets
To simplify integration, SafeSky provides ready-to-use traffic icon sets optimised for map rendering.
📦 Icon sets download (placeholder):
https://docs.safesky.app/downloads/iconsets
Includes:
- SVG and PNG formats
- Multiple sizes
- Dark and light themes
9. Recommended Timing Summary
| Action | Interval |
| GET traffic (viewport) | 1 second |
| POST UAV telemetry | 1 second |
| Pre-flight GROUNDED publish | 3–5 minutes before takeoff |
| Start uncertainty | 30 seconds |
| Discard traffic | 45 seconds |
10. Reference Implementation
A live example implementing all these best practices is available at:
