API definition
  1. Get an API Key:
  2. Make API Calls:
  3. Authentication:
Endpoints Overview
Sandbox
  • Key Features:
    • Simplified environment with limited traffic data.
    • Ideal for debugging, testing payloads, and verifying integration.
  • Endpoint URL: https://sandbox-public-api.safesky.app
  • API Key: You will receive a sandbox-specific API key upon registration. Ensure this key is used exclusively for sandbox testing.
Production
  • Key Features:
    • Access to all real-time traffic data, including manned and unmanned aircraft.
    • Supports high-availability operations with optimized performance for production workloads.
  • Usage Guidelines:
    • Ensure robust error handling and retry mechanisms in your application.
    • Follow the recommended request limits to avoid throttling.
  • Endpoint URL: https://public-api.safesky.app
  • API Key: A production-specific API key is required. This key must not be shared and should be stored securely following best practices (e.g., environment variables or secret management systems).
Aircraft lifecycle and status
SafeSky automatically manages the lifecycle of published aircraft based on the latest traffic timestamp. With multiple data sources, the most recent information is always prioritised for exposed traffic.
Aircraft can have one of three possible statuses: GROUNDED, AIRBORNE, or INACTIVE. If an aircraft stops transmitting its position, the last known position will continue to be provided with an INACTIVE status for up to 30 seconds. After this period, the aircraft will no longer be visible.
1. Get Nearby Aircraft
Endpoint: GET /uav
Endpoint: POST /uav
Description:Publishes one or many UAV position to the SafeSky platform. Optionally, it's returning a list of nearby aircraft for each UAV position within a radius of 10000 meters.
Example POST Request:
3. Check for API health
Endpoint: GET /
Description:
