API definition
Get an API Key:
Make API Calls:
Authentication:
Endpoints Overview
Sandbox
Key Features:
- Simplified environment with limited traffic data.
- Ideal for debugging, testing payloads, and verifying integration.
Important Note: The sandbox environment does not represent the full scope of the live production environment and should not be used for live operations.
Endpoint URL:
https://sandbox-public-api.safesky.app
API Key: You will receive a sandbox-specific API key upon registration. Ensure this key is used exclusively for sandbox testing.
Production
Key Features:
- Access to all real-time traffic data, including manned and unmanned aircraft.
- Supports high-availability operations with optimized performance for production workloads.
Usage Guidelines:
- Ensure robust error handling and retry mechanisms in your application.
- Follow the recommended request limits to avoid throttling.
Endpoint URL:
https://public-api.safesky.app
API Key: A production-specific API key is required. This key must not be shared and should be stored securely following best practices (e.g., environment variables or secret management systems).
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
lat |
lng |
alt_min |
alt_max |
rad |
Endpoint: POST /uav
Description:
groundSpeed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
or visit our website.
