API definition
Getting Started
  1. Get an API Key:
  2. Make API Calls:
  3. Authentication:
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
Endpoint: POST /uav
Description:
Example POST Request:
