Getting started
Getting Started
Get an API Key:
Make API Calls:
Authentication:
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
lat |
lng |
alt_min |
alt_max |
rad |
Endpoint: POST /uav
Description:
groundSpeed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
or visit our website.
Disclaimer
