Getting started
Getting Started
  1. Get an API Key:
  2. Make API Calls:
  3. Authentication:
altitude int Yes Height of the UAV in meters, based on GPS altitude AMSL.
altitudeAccuracy int No Accuracy level of the altitude coordinate in meters.
callSign string No UAV call-sign.
groundSpeed int No Current ground speed of the UAV, specified in meters per second.
lastUpdate long Yes The time of the event in seconds since epoch at UTC-0.
turnRate float No Turn rate in degrees per second.
verticalRate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent.
callSign string No Beacon call-sign, available only if the pilot has a public profile.
groundSpeed int Yes Current ground speed of the beacon, specified in meters per second.
beaconType string No The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, etc.
transponderType string No The type of transponder broadcasting the position. Allowable values: ADS-BI, FLARM, ADS-B, etc.
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
Endpoint: POST /uav
Description:
Example POST Request:
Disclaimer
